First RL Problem
Old Apr 2, 2007 | 10:57 PM
Riddler2222's Avatar
06 RL Lakeshore Silver
First RL Problem
Well, I have owned by RL for six months and have found my first problem. Key FOB will not open the drivers side door, only the right passenger and trunk. I have to pull the remote out when I want to get into the car. (Yeah, I'm lazy) but when you get used to it, it's a great thing.
Starting the car is not a problem. I have a date with my service guys on Friday, they claim it's no big deal. Will see.
Old Apr 2, 2007 | 11:06 PM
GoHawks's Avatar
2012 Cadillac CTS-V Coupe
Has it been raining or did you recently wash it.
Known problem.
Old Apr 3, 2007 | 08:03 AM
Touge's Avatar
My driverside handle just went on me recently too, but it magically started working again 2-3 days later... Odd.
Old Apr 3, 2007 | 09:54 AM
GoHawks's Avatar
Those were the exact symptoms I had. If I washed it, or especially if I took it to a touchless with the high pressure water, or it rained, it wouldn't work. It would take a day or two for it to dry up and then it would start working again.
Took it to the dealer, there is a TSB out there. Seems like the lighter colors are more prone to it, but obviously that didn't apply to me with the CGP.
Service Manager stated that the replacing of the door handles is temporary since they didn't think Acura figured out the problem. So far the new one (passenger side) has been working well, but now I think the driver's side may be starting to go. Had one instance where I almost had to rub the dimple (no comments) instead of just touching it, and that was when the car was wet.
Old Apr 3, 2007 | 10:09 AM
Alpha Geek
Had mine since last August with Zero problems, and I've been through many car washes in that period.
Old Apr 3, 2007 | 05:59 PM
Dr. Colorado's Avatar
Had same problem last year. Dealer exchanged both driver and passanger side handles under warranty and no problems since then!
Old Apr 3, 2007 | 06:22 PM
Roy Cya's Avatar
I had that happen, and the dealer did a complete "reset" whatever that means and it started working again. I've also had the driver's side handle replaced but that was after the first issue.
Good luck!
Old Apr 3, 2007 | 09:56 PM
It didn't happen after car wash. Been this way for about a month off and on, now it's 100% off.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
