Figure this one out, HELP!
I have an 05 RL with 70,000 miles.
Drove home last night with no problems.
Go out today and the car does not acknowledge fob. I had to use the key to open the door. The car would not start normally. I also had to use the key to start the car. It did start. But the horn blew for two minutes before stopping.
Here is what does not work:
Nav screen does not work. No climate, no radio info......blank. Radio does work.
Driver seat only moves when car is running. Pass seat OK.
Power door locks do not work.
All presets on radio are off by one button. 1 is 2, 2is 3, 6 is 1 etc......
Gas guage reads full. The tank is not full.
Push the center Nav knob and only rer speaker work.
Everything else works fine.
It is at the dealer right now.
Any ideas?
Any ideas?
It will be interesting to see what the verdict is. My first reaction is the fob battery is dead, but you should have been given a warning about that. I suppose that you could have worn out the fob battery. I remember that one time, I was sitting in the house, and a car alarm went off the honking. I figured it was in the street, since I was on the second floor. I was later on the first floor and heard it again, only this time it sounded like it was in the garage, and of course it was the RL.
It turns out I had taken the fob off my key chain and gave it to my wife because hers was somewhere else inconvenient. I put it back on the key chain, and apparently the orientation was reversed, and whenever I sat in a certain position, part of the key chain was leaning on the panic button. I suppose you could have done something like that and drained the battery while not in proximity to the car.
Hmmm, widespread electronic craziness. This is going to be way over the head of any DIYer and very possibly the dealer too. The only single point of failure I can see here is the ECU. My guess is it got cooked somehow.
I had the same symptoms when my battery cable was loose after changing the battery
I bet the car battery is very low or loose cable. by coincidence, I have 2005 with 70K miles and I replaced the battery about a month ago
Battery issue, cost 100 bucks for new battery. My battery started to fail this winter which caused a myriad of electronic gremlins. I took it to the Honda dealer and they told me it was fine. The next day it started acting up again. I went to the Acura dealer to pick up our new MDX sport (DREAM SUV STRONGLY RECOMMENDED) and I also picked up a new battery for the RL, problem solved and it was only 100 bucks. Simple DIY job. My acura dealer is 100 miles away so simply swapping the battery myself was a cheaper and simpler proposition. To get your radio and nav systems back you must enter the appropriate codes, if you don't have them somewhere (I keep mine in owners link) simply call your dealer and they will tell you.
Regarding owners link, you can now buy any part for your vehicle direct, it comes to your home in a day or 2. Its an excellent thing to have, you can now have the same ordering mechanism that the dealer has and have it shipped home pronto it saves trips to the dealer. Finding some parts is a little frustrating but still well worth it.
Battery is fine. It turned out to be the drivers door handle. They are overnighting a new one and it should be good to go tomorrow. I am only paying for the handle. The 4+ hours of labor they are taking care of. Good deal.
3.2 VTEC
Any ideas?
Any ideas?
nav, radio, climate control not working...WTF
driver's seat moving...WTFFF
presets rotating 1 position to the right...i think sum1 is fucking with you.
gas gague...yes, some1 is definately fucking with you.
next thing you know, your brakes are gonna be cut.
lol jp
seems odd to me that it was the door handle, but you never know
I would take the battery out and have it tested. A good early warning on the battery going is that the steering wheel stops adjusting when you start the car. I had this symptom for 3 months before replacing battery. Had battery tested - showed good voltage, but failed the load test.
I had the same issue it was also the dirver door handle. The passenger one also had an issue it wouldnt lock when you press the dimple.
After they changed boith handles I am now having a problem while driving it seems as thought the locks try to lock periodically. This happens when I drive for a while and it will just try to lock on its own.
there was a TSB on 05s regarding the doors locking periodically while driving. It was one of the very first issues.
Well the handle came in. Wrong part in correctly numbered box. Next day the handle comes in. I pick the car up Sat. While driving the doors try to lock themselves a couple times, Nav screen does not save settings when you turn off car and restart, gass guage doesn't work.
Take the car right back. I egt some problems fixed, but get two new problems. My dealer in an hour away and I am getting frustrated. It was last summer when I waited 5 WEEKS for an AC Compressor.
I'm surprised that when you brought it back, they didn't just do the reboot. Were they closing when you brought it back?
will tell you.
will tell you.
Are you referring to an alternate method of ordering OEM parts? If so, would you achieve any savings vs. using the dealership/MyAcura.com method?
I am searching for a way to buy OEM parts directly and bypassing the dealership mark up. I honestly do not know if this is possible. I would predict that Acura protects the dealership from this happening.
Torch & Pitchfork Posse
There are several official vendors in this forum and several OEM vendors online that will almost ALWAYS be less than you dealership (even with shipping). Of course for many accessories, Ebay is also worth a shop and many Acura Dealers are found there.
2017 TLX AWD Adv FBP/EB
I am highly interested in this owners link statement. I am aware of registering with MyAcura.com and being able to purchase OEM parts and have them shipped to your home. But in actuality, the order is processed by your closest Acura dealership and you pay as much as when you went directly to the dealership. It is simply a more convenient. A
Kaleb Cunningham __________________
---WholesalePartsGuy
Show'n the luv to Acura Enthusiasts!
Always 20% off for Acurazine Members!
Shop online at:
http://www.prestigeacura.com/estore_parts.htm
Note: eStore pricing does NOT reflect Acurazine Member Discounts.
Prestige Acura
707-578-3960
kcunningham@hanselauto.com
BigKat, First and foremost: I love your RL.
I appreciate the lead. I will be making contact as I have a small list of things I need. A few items are really specific like a new front undercarriage splash shield.
kb1rl
09-30-2015 10:17 AM
