Exterior Lighting (Plate and Reverse Lights)
Old Jun 15, 2012 | 09:51 PM
BluNosr2's Avatar
Is there any kind of LED replacement option that works to make the plate/tag and reverse lights significantly brighter?
Old Jun 15, 2012 | 10:02 PM
BDoggPrelude's Avatar
There are plenty of options available. Do a little searching:
https://acurazine.com/forums/search....rchid=10561638
Old Jun 16, 2012 | 08:25 AM
coopcoop30's Avatar
Link doesn't work.
Old Jun 16, 2012 | 09:09 AM
oo7spy's Avatar
The license plate lights are T10 wedge bulbs (2825). The reverse lights are 7440 which usually has a more common like "T10", but I don't know what it is.
Pretty much any T10 led with 4 or more smd LEDs will be brighter than stock. As for reverse, I would imagine you will want to look for some high power non SMD bulbs to be brighter. I haven't done those, so I'm not sure what the options are.
Old Jun 16, 2012 | 10:16 AM
RL Chi-town's Avatar
Chapter Leader (Chicago)
link no workie...
Old Jun 16, 2012 | 11:55 AM
sleepinxlionhart's Avatar
Lets see if this works..
Here's my car:
Old Jun 16, 2012 | 03:45 PM
CanUSayChiCity's Avatar
Well one of my plate lights went out so I'm going to replace them with brighter LEDs. Makes the car look much better. Thanks guys.
Old Jun 16, 2012 | 04:05 PM
BluNosr2's Avatar
How tough is it to get at the bulbs to replace them? The plate lights don't look so bad but I'm not so sure about getting at the reverse lights....
Old Jun 16, 2012 | 05:50 PM
The plate lights, you have to go from the inside of the trunk to get to them. The service manual says you can go from the outside, but I found that to be impossible without using an insane amount of force. Basically, just take the trunk liner off and you have full access to them:
There should be a DIY topic somewhere on this forum...
The reverse lights should be a lot easier. You just have to take out the whole housing by prying (?) off the plastic covers on each medial side of the taillights when you open up the trunk. And under it should just be screws to loosen, and you should be able to pop out the taillight housing as a whole. The thing about the reverse lights is that you have to make sure the LEDs you buy can fit through the access hole into the housing. Other than that, it should be pretty easy. I would have done the reverse lights, but the LEDs that I wanted were 50 bucks for a pair...kinda expensive if you ask me.
Old Aug 26, 2012 | 06:27 AM
GGENOVESE's Avatar
Hey guys. I'm contemplating replacing my license plate lights also. I'm planning on purchasing them from superbrightleds.com and i'm not sure which 1 to buy. Your suggestions would be greatly appreciated. http://www.superbrightleds.com/cat/l...1-888--367428/
Old Aug 26, 2012 | 10:20 AM
oo7spy's Avatar
Any of those would work except maybe the last one. However, the only one I would even consider buying is this one because it is less than $2/bulb. http://www.superbrightleds.com/morei...d-product/198/
eBay has the same stuff for way cheaper than any of these US sites. All of this stuff is made in China anyway; why not cut out the middle man trying to make his dollar off of you? I bought all ten of my interior T10s on eBay for $2 shipped a year ago, and I haven't had 1 burn out. Any warranty or garauntee talk on a $1 led bulb is a joke.
Old Aug 26, 2012 | 10:54 AM
HEAVY_RL's Avatar
mada51589
Jan 9, 2025 04:40 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
Mcj270
Aug 31, 2015 04:45 PM
