Engine undershield cover necessary?
Old Mar 7, 2017 | 10:17 AM
DanL07RL's Avatar
Did a search and found nothing.
My undershield cover got torn up and so I removed it. Any reason I should replace it.....it's a PITA on oil and transmission fluid changes!!
Old Mar 7, 2017 | 12:36 PM
teh CL's Avatar
Haven't put mine back on in some time. More annoying than anything
Old Mar 7, 2017 | 01:05 PM
projektvertx's Avatar
There is no reason why you HAVE to put it back on there...
Old Mar 7, 2017 | 02:04 PM
TonyCD's Avatar
It might reduce the noise level a bit. Some engine covers are engineered to do so.
Old Mar 7, 2017 | 02:50 PM
oo7spy's Avatar
I thought it was to protect the engine bay from unnecessary water intrusion via splashing that would lead to corrosion.
Old Mar 7, 2017 | 03:33 PM
I always thought it was for aerodynamics and to prevent various potential shrapnel from hitting the bottom of the engine.
Old Mar 7, 2017 | 03:36 PM
Technically, yes, but its not ABSOLUTELY necessary... I personally wouldn't take it off my car, but that's me. What puzzles me is the fact that it gets in the way of oil changes for OP. I can reach the filter by turning the steering wheel all the way to the right and the drain bolt is exposed....
Old Mar 7, 2017 | 04:00 PM
DanL07RL's Avatar
You know? You're right....I can change the oil with it on. I was thinking of my Volvo.
The service guy cited protection from rocks as the reason it's there.
Old Mar 7, 2017 | 05:47 PM
oo7spy's Avatar
The transmission plug is definitely blocked, but I would think you could southern engineer a solution to that without removing the whole thing.
The small rock idea makes sense. My Tundra has a 1/4" steel plate for big rocks.
Old Mar 8, 2017 | 06:19 AM
08KBP_VA's Avatar
I recently replaced mine as someone hacked the hell out of the old one not sure for what purpose but it was virtually non existent. I was quite pleased on the replacement cost vs my M5.
I keep these on all my cars but is it "necessary", no! I do think in my instance it lends some structure to front bumper to tie it down a bit esp with underbody spoiler I have.
Old Mar 8, 2017 | 08:23 PM
TonyCD's Avatar
Apologies for dumb answer. Somehow I didn't read the word "undershield." Duh.
AtlM5
Jan 25, 2017 03:54 PM
ggesq
Nov 2, 2016 09:52 AM
maharajamd
Oct 20, 2016 04:10 PM
maharajamd
Oct 18, 2016 12:14 PM
ExcelerateRep
New England
Oct 4, 2016 04:01 PM
