Engine Temp Goes Up when AC is on Auto
Old Jun 30, 2016 | 03:23 PM
GaRaS's Avatar
Engine Temp Goes Up (75%) when AC is on Auto but if its on circulation mode it goes back to normal no matter what the temperature settings. I had already the parts to replaced the radiator cap, engine temp sensor (2) and thermostat this coming Saturday. Anyone has experienced this?
Old Jun 30, 2016 | 04:08 PM
oo7spy's Avatar
That's dangerous with your aluminum heads/block.
I had a temperature issue on my 2G Legend that was much worse with A/C, and it turned out to be the thermostat getting stuck. That may not apply though.
Old Jul 1, 2016 | 06:32 AM
projektvertx's Avatar
That almost sounds like the system isn't generating enough pressure. In addition to all you've already ordered, when was your water pump replaced?
Old Jul 1, 2016 | 10:59 AM
4strokes's Avatar
Have worked on MANY vehicle brands as a mechanic throughout my life .... but have very little shop time on Honda/Acura ... except Honda motorcycles.
With that said, I've never experienced a car that would come up to "normal temp" on the gauge as quick as the RL we just acquired.
I realize it's summertime in the south & hot as hell but my car is up to the normal temp on the gauge before I reach the end of the road that I live on & it's only 1/2 mile long.
Granted, it doesn't rise any farther than that while driving with a/c ON & I've been keeping an eye on the gauges, especially in town.
Anyway, in my experience in situations like yours, I'd be looking at possible electric fan failures & their sensors & air trapped in the cooling system on top of the things you're already preparing for.
The cooling fans on most cars are designed to come ON when the a/c does.
Good luck
Old Jul 1, 2016 | 11:01 AM
^It actually didn't even occur to me until you said it, op check to see if the fan comes on when you turn a/c on. That might be what's happening too.
Old Jul 1, 2016 | 01:43 PM
oo7spy's Avatar
While we're here, the driver's side fan is for the radiator and the passenger's is for the A/C condenser.
Old Jul 2, 2016 | 10:38 PM
GaRaS's Avatar
Thank you all for the tips, I have completed replacing the thermostat, 2 temp sensors and as well the radiator cap. After completed i use lisle to burp the coolant for trap air. The car has been service for the timing belt as well the water pump, car now has 165k. I had the car running for 45 mins with the AC full blast at auto mode, outside temp is 81 degrees and the temp never move and stayed at 40%. Still early to tell need to test the car when it reaches 100 degrees on the weather here in LA. About the fan both kick in when the A/C is not on and turned off, When the A/C is on both fan still kick in. I had replaced the A/C condenser fan 2 months ago since its making a grinding sound.
gavriil
Aug 20, 2025 04:43 PM
00TL-P3.2
Feb 11, 2019 11:23 AM
Black Tire
Dec 18, 2017 08:15 AM
Stew4HD
3G RLX Problems & Fixes
Jan 29, 2016 03:32 PM
GK83
Sep 13, 2014 12:48 AM
