Easy visual diff between Base and Tech ?
Old Jul 19, 2009 | 08:47 PM
123456SPEED's Avatar
CLS 6MT Navi
Sorry if this is lame and I didn't think hard enough before asking-
Are there easy visual clues to the base model vs the Tech?
I know how to tell the CMBS model, but what about Tech or base. I'm talking about from pics on Autotrader.
Unless the screen is on and you see a compass, (not sure if even that denotes only a base).
thanks xperts.
Old Jul 19, 2009 | 10:41 PM
TampaRLX-SH's Avatar
Torch & Pitchfork Posse
If you look on the center stack, the MAP button for the NAVI will say COMPASS for BASE (non NAVI).
Old Jul 20, 2009 | 11:41 AM
Chas2's Avatar
This is extremely subtle, and depends on the photos...
the base model (2007-2008--assuming you are not talking 2009) has no rearview camera mounted left of centerline under the license plate trim. It is possible to retrofit a rearview camera in the base, but it uses the same kit as the 2006, where the camera is mounted dead center, in place of the trunk mounted release button (a new button is installed right of center, but you will not be able to see that in any picture unless you get an extreme low angle rear shot with high resolution.
Tampa's method is likely to be easier to use.
Old Jul 20, 2009 | 12:08 PM
psheu's Avatar
also the wood dash trim... but u have to put them side by side to compare and tell the difference
Old Jul 20, 2009 | 12:43 PM
Another obvious visual would be a blank button for the AFS alongside the gauge cluster. BASE RLs do not have AFS, althought you cannot really tell from looking at the headlight assembly.
Old Jul 20, 2009 | 01:03 PM
CLS 6MT Navi
Thanks. On autotrader, I see a good price on a 07 I think it was, and they show the on-screen compass. I'm thinking probably Base. Does the Tech model have the compass too?
So for CMBS/ACC, we get the shield on the grill, and the right buttons on the steering wheel, and one more button on the dash I think.
For BASE we have a Compass button and no AFS button..
Also- can you detect from the VIN what trim it is?
Old Jul 20, 2009 | 01:15 PM
CLS 6MT Navi
I see elsewhere that Vin digit 8 denotes trim level.
This 07 has a 5 as 8th digit.
I'll email the dealer, but 50/50 chance they even know what color it really is!!
Old Jul 31, 2009 | 09:57 PM
larrynimmo's Avatar
07 RL (non-tech)w/06 Nav
in case you need it I still have a nav unit....put it in the trunk, plug & play for the non=nav units.
uzzmaan
Jun 17, 2026 08:56 PM
Feb 25, 2020 09:57 AM
TLDude876
Dec 28, 2016 03:18 PM
Sep 17, 2015 10:16 AM
