Driver seat wont recline!!
Old Jul 28, 2013 | 03:35 PM
Toppatop's Avatar
I have spent over an hour serching for similar threads without any luck. My driver seat backrest wont mmove forward unless i recline it backward first. Could this be a sign of somthing worse? Battery is ruled out.
Old Jul 28, 2013 | 08:31 PM
sOLLEx's Avatar
So you have to recline the seat back all the way back before it will move forward to your desired position?
Old Jul 28, 2013 | 08:32 PM
oo7spy's Avatar
Sounds like you may need to do a hard reset with the battery cables. Disconnect both cables and hold them together for ~1 min.
There are a number of automatic system reset procedures, but I have never seen one for the seat.
What happens if you leave the seat out of position and press the seat memory button?
Old Jul 28, 2013 | 08:44 PM
Toppatop's Avatar
No, not all the way down only a couple inches back then it will allow me to move it forward.
Old Jul 29, 2013 | 07:34 AM
sOLLEx's Avatar
Try and put pressure on the seat back with one hand and holding the recline button to see if assisting the motor helps. Have seen this before and ended up being a recline motor.
Old Jul 29, 2013 | 11:44 AM
Toppatop's Avatar
Is the reclining Moro an expensive fix? Or is there a part number I can serch the junkyards for?
Old Jul 29, 2013 | 03:23 PM
sOLLEx's Avatar
You can buy the recline motor separate from the seat linkage itself...not sure on the price. I doubt your extended warranty will cover it either but you should have your dealer call and see.
Old Jul 29, 2013 | 03:34 PM
Toppatop's Avatar
Would you happen to know the part number for the reclining motor? I tried searching but came up with module.
Old Jul 29, 2013 | 03:37 PM
Toppatop's Avatar
Ok disregard the last post I just found it reclining motor 81637-SJA-A01.
Old Jan 12, 2015 | 04:43 PM
Toppatop's Avatar
Has anyone solved this issue of the reclining motor? Mine still reclines back but not forward unless you recline back a little then quickly forward. The memory seat buttons will attempt to bring the seat back but the back rest part doesn't lit make it. Could this be a motor problem or frozen gears. No noise is heard while attempting to recline forward.
Old Jan 12, 2015 | 07:35 PM
sOLLEx's Avatar
Same thing it was a year and a half ago.
BoricuaTL
Apr 8, 2016 01:08 PM
cm561
Jan 27, 2016 10:17 PM
Joeyc850
Oct 30, 2015 12:15 AM
kareshi
Sep 3, 2015 03:38 PM
