Driver Preference Option Settings
Old Feb 10, 2012 | 09:35 PM
M T L T L's Avatar
When I 1st bought my RL, I remember seeing a driver settings menu where you could configure the how does the door locks react to keyfob inputs. There was a option to chose wether to unlock all doors upon a single press of the unlock button or just the driver door and etc. I can't seem to find that menu anymore. I went through all buttons and menus but no luck. Anyone knows what I'm looking for here ? One thing though, I have upgrade to 4.92 v straight from the 2006 version of the Navi. Could this be the prob ?
Old Feb 10, 2012 | 11:38 PM
oo7spy's Avatar
First off, the MID and nav are two separate and independent systems. You need the MID settings controled on the steering wheel. Once in the menu, there is a sub menu called "keyless access". This is what you are looking for. There is another sub menu called "lock settings" where you can control which doors unlock when shifted to park, the auto lock speed, and possibly more. This is all of hand BTW, so accuracy may be lacking.
For more complete instructions, .
Old Feb 10, 2012 | 11:55 PM
M T L T L's Avatar
Im talking about the Nav system also. Those keyless sub menus and lock settings are exactly wut im looking for but I can't find. Had stumbled on them once but no luck now. Do u know the menu path to reach those settings ?
Old Feb 11, 2012 | 12:01 AM
oo7spy's Avatar
With the car in park and the ignition on I or II (where the MID is displaying), hold the button that has the "i" within a circle. This should pop up a change settings menu. You will have to isolate each fob to set the settings for each. Go into the menu and that's where the sub menus are.
If you hold that button long enough, it will prompt you to reset the maintenance minder. If you get there, press "exit".
(The MID (Middle(?) Information Display) is the one below the speedometer and the controls are on the steering wheel.)
Old Feb 11, 2012 | 12:08 AM
M T L T L's Avatar
Oh so its in the MID. I was under the impression that its accessed through the NAV unit. Will look for it tomorrow n let u know how it goes.
Old Feb 11, 2012 | 10:56 AM
oo7spy's Avatar
I just confirmed. Hold the "i" button with ignition on II. To reset minder hold "reset" for ten seconds.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
nanos
Nov 12, 2015 08:41 PM
braveheart
Sep 7, 2015 08:12 AM
