Diff fluid change
Diff fluid change
After reading the various posts here on how to drain and refill the diffs, I tried to do it today. Trouble is in the rear there are 2 drain and fill units. one has the drain and fill facing the rear of the vehicle, and the other has the drain and fill on the left side of the vehicle. Are these both diffs, or is one a transfer case ? do they all take the ATF fluid??
Thanks!
Confused!
Acurod
Thanks!
Confused!
Acurod
Thanks!
Confused!
Acurod
Thanks!
Confused!
Acurod
Thanks everyone! I did the job today and it took me less than an hour to do the front and 2 rear diff drains and fills as well as the tranny. I used the ATF-Z1 fluid everywhere, but did notice that in some of the diffs an oil that was not red was in there. Maybe some po had filled with the wrong fluid??
Anyway, it was pretty easy, only trouble was getting to the tranny fill bolt-- that was annoying, as discussed in other posts!
My next project is to change the drivers side HID bulb. This maintenance is fun!! And look at all the $$ you save by doing it yourself!
Total cost for the diffs and tranny was 6 quarts of ATF and a few crush washers (that I got from Acura). Oh, and I did buy a hand pump that fits right onto the quart containers of ATF to pump the fluid up into the diffs. easy!!
Acurod
2005 RL
Acurod
2005 RL
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
