Current Recall Notice on the 05 RL
Old Sep 28, 2005 | 10:42 AM
Professor's Avatar
Карты убийцы
Does anyone know if the current recall to fix the XM delay, ONSTAR powerloss, and transmission PCM simply reprogramming or are they replacing parts?
I don't know if I want to take mine in since all that stuff seems to be working fine. With my luck, problems will begin after the fix.
Old Sep 28, 2005 | 10:52 AM
Rob L's Avatar
office monkey
i say if things work then dont bother taking it in. If things break then take it in
vp911's Avatar
I think the acura link control module is actually replaced. The PCM is a software update I am sure. Onstar I am not sure about. Look at the PDF of the TSB in the other thread and see if it calls for replacement of parts - that is the intructions that the technicians will use to do the work.
Old Sep 28, 2005 | 11:12 AM
ASP's Avatar
ASP
Earl Shod
Not a recall, but a technical service bulliten. Big difference.
The details of what is performed can be found here -> https://acurazine.com/forums/showthread.php?t=998
Just click on the link to the PDF and read the procedures within . . .
hendjaz's Avatar
No recall
Just to be clear, there is no recall on the RL. Those are service bulletins where upgrade/adjustments are being made, primarily to software. I believe only the transmission software update is actually Acura as the others are XM and Onstar related. I would suggest inquiring whether your vin # is covered in the bulletins as I don't think more recently purchased RLs may need all of the updates, but not sure about that. I have a very low/early vin # so all applied to me and had them done during recent scheduled oil change. Worth inquiring imho.
rockyboy
Aug 4, 2024 10:35 AM
TL-Rocket
Apr 29, 2023 02:33 AM
merc009
Jan 27, 2016 10:34 AM
01CLOwner
Oct 9, 2015 01:07 PM
