Climate Control
Old Aug 21, 2008 | 09:37 PM
MarkCraig's Avatar
Climate Control
Hey, Anyone have any trouble with their climate control? I have a 2005 RL and I am having intermittent trouble with AC blowing warm air, low air volume as well as defrost not working. It will work for a while then stop working then start up again. Kind of weird. Any help out there?
Old Aug 21, 2008 | 10:32 PM
nyctl's Avatar
read or search first dude
Old Aug 22, 2008 | 12:58 AM
csmeance's Avatar
search isn't working yet. The 05 RL has had problems with the a/c, take it to your dealer to repair under waranty.
Old Aug 29, 2008 | 09:50 AM
Gabe15's Avatar
Poor A/C Performance or A/C Doesn’t Work
Currently Applies To: ’05–06 RLs
Got a vehicle in your shop because the A/C runs poorly or doesn’t work at all? A bad field coil in the
A/C compressor clutch could be the culprit.
To determine if this is the case, connect the HDS, go to the DATA LIST, and monitor the A/C switch and
A/C clutch relay signals. If the DATA LIST indicates that the A/C switch and A/C clutch relay are on—and
the A/C compressor clutch isn’t working—refer to step 4 on page 21-91 of the ’05–08 RL S/M and measure
the resistance of the field coil. (Online, enter keyword COMPRESSOR CLUTCH and select A/C
Compressor Clutch Check from the list.) If the resistance isn’t to spec, replace the field coil with
P/N 38924-RJA-A01.
The above was posted before and happened to be exactly what was wrong with my climate control on my 05 RL. I had the same intermittent trouble you are having. Since I got the new field coil 3 weeks ago Ive been all good.
Old Sep 12, 2008 | 09:58 PM
dlynch's Avatar
Too Many Cars
Great post. Thanks!
DaveL with new-to-us 05
knight rider
Mar 4, 2016 08:59 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
adreano17
Sep 29, 2015 08:48 AM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
Brandle34
Sep 23, 2015 07:20 PM
