Cleaning Headlights
Old Nov 10, 2014 | 02:29 AM
kei0kusanagi's Avatar
Cleaning Headlights
I own a 2005 Acura RL and the headlights are getting foggy. What do you guys suggest for cleaning and how to clean a foggy headlight. Thanks.
Old Nov 10, 2014 | 05:41 AM
HEAVY_RL's Avatar
The easiest is to take it somewhere.
Depending on how bad they are you could attempt a home kit.
Old Nov 10, 2014 | 08:33 AM
beekermartin's Avatar
Amazon.com: Sylvania Headlight Restoration Kit: Automotive Amazon.com: Sylvania Headlight Restoration Kit: Automotive
I used that kit and it worked great. Follow the video and make sure to apply the last step as smoothly as possible.
Old Nov 10, 2014 | 10:07 AM
bugeyes's Avatar
Wet sand, then clear coat.
This way they will not fade out again two months later.
Old Nov 11, 2014 | 03:31 AM
Nice!! thank you guys so much, I will try it.
Old Nov 11, 2014 | 02:43 PM
Essential the Sylvania kit includes different levels of fine grit sand paper. You clean the lenses and sand them using progressively less aggressive sand paper. When you are done the kit includes a clear coat that needs to be applied as smoothly as possible because you only have one shot to apply it.
There is a great video on Amazon/You tube that shows the procedure. It isn't difficult but time consuming.
Old Nov 11, 2014 | 03:44 PM
oo7spy's Avatar
This topic has almost as many hits as "dead battery".
Prime threads found by searching "haze" in the "search this forum" toolbar:
https://acurazine.com/forums/second-...ke-new-911733/
https://acurazine.com/forums/second-...lights-832715/
https://acurazine.com/forums/second-...t-lens-823759/
Old Nov 11, 2014 | 05:57 PM
knv8's Avatar
i say take it to a pro, i had both mine done with clear coat for $60 or $70.
Old Nov 12, 2014 | 07:34 AM
projektvertx's Avatar
I've been told you can put opti-coat on top of it once you clear them out to protect the headlights from hazing out 2 months later. I haven't attempted this, so I can't vouch for it.
Old Nov 13, 2014 | 11:34 AM
VNMISS04's Avatar
Mine were horrible too. I just went cheap and used the Turtle Wax kit. I'm sure it is less than permanent and will be back soon but I'm happy with the "temporary" results though. I did them about two months ago and so far they are still clear.
Before (yes my tape job sucked lol)
After
Old Nov 13, 2014 | 01:01 PM
bugeyes's Avatar
Looks Good
Old Nov 13, 2014 | 01:54 PM
oo7spy's Avatar
That looks great, Stephanie. IIUC, the root cause of the hazing is prolonged exposure to sunlight. If you restore them and keep the car covered from the sun, I wouldn't expect it to come back.
Old Nov 14, 2014 | 05:32 PM
tsi91at's Avatar
I read not to clean them ... but just wondering if anyone else has haze on the CMBS front sensor cover like I do?
I am getting the ACC/CMBS warnings (this can be another thread) so wondering if that could cause an issue as our cars age (2006).
Old Nov 14, 2014 | 07:11 PM
F35PHIXER's Avatar
i had to do my benz, did with a meguair kit, worked good, i FORGOT to put UV protectant on and they hazed after about 6 months. I now put on UV protect on after every wash....
Old Nov 15, 2014 | 09:22 AM
oo7spy's Avatar
The grill shield is just plastic. Its only purpose is to protect the CMBS unit behind it. Many have done the same restoration to their shield as their headlights without issue.
Jul 16, 2017 07:33 AM
rockyboy
Sep 29, 2015 12:05 AM
jmaxima03
Sep 27, 2015 10:22 AM
AmplifiedDetails
Sep 24, 2015 02:55 PM
