Check VSA fault code after chip key programming
Old Jul 6, 2019 | 12:01 PM
nishant11's Avatar
2008 RL. Had only one remote and key. Tried local mechanic to reprogram newly bought chip key & remote. He could not program. Now it give fault code " Check keyless entry system"
Took car to local reputed transponder programming shop. Second set of remote and chip keys are programmed.
Keys work fine with newly added Driver 2 set.
However
a) Check keyless entry system fault code remains
b) New fault code of "Check VSA system" in orange letter on speedo display panel only with driver 2 remote
c) When tested with original Driver 1 remote, I do not get orange letters fault code on speedo display however yellow triangle exists when car is started with either remotes
Is there a way to clear the fault codes?
Old Jul 8, 2019 | 10:55 AM
RL09's Avatar
FkNo!TheyRdstroyinEvrting
If some total reset was made for some reason.. you may need to do 'neutral position memorization' for the VSA to go away.
Look online, or a honda compatible scanner can do it in the options.
Old Jul 8, 2019 | 01:20 PM
RL09's Avatar
oh btw:
a: is that on both remotes? check remote battery.
c: the yellow triangle follows VSA. Do my previous post, the yellow triangle goes away.
angeljr8282
Jul 31, 2018 10:49 AM
wmahmud
4G TL Problems & Fixes
41
Jan 3, 2017 11:12 AM
piggydog
Feb 11, 2010 11:05 AM
pickncrew
Aug 28, 2009 06:13 PM
cjhanson
May 4, 2006 09:44 AM
