Check Radiator System
Old Sep 28, 2013 | 03:20 PM
mrm143's Avatar
Hello everyone
Back again with an issue
2007 RL
Getting the "check radiator system" message
Car doesn't seem to overheat, the fans do kick on, but not ALL the time, so its more of an intermittent issue
Car will overheat if it sits, if I turn it off and back on, sometimes fan will kick in and all is ok
Battery replaced less than a year ago
Checked 50a fuse on battery looks ok
Moved relays around, I believe it is the 2 light green ones under the hood?
What other things can I check
Thanks again
Old Sep 28, 2013 | 05:36 PM
HEAVY_RL's Avatar
is there coolant in the car?
Old Sep 28, 2013 | 06:57 PM
sOLLEx's Avatar
Can you confirm that both fans are running when the car is running and the a/c is switched on? If only the condenser fan is running,(the fan on the passenger side of the car) and not the radiator fan, then yes the car will start to overheat. Have seen several of these fan motors fail...what code is storing on the navi screen?
Old Sep 28, 2013 | 07:46 PM
mrm143's Avatar
Its very intermittent it came on tonight on my way home... I got home and popped hood no fans running... I turned of the car and back on and within 3 minute's fans kicked on.. They then proceeded to cycle on and off every few mins....
Ac fan does come on with ac but again same thing it has stopped.... Very intermittent.
And yes their is coolant in the car lol
It seems like whatever is telling the fans to come in may be the issue? I have no idea seems weird
Navi gives same message if remember correctly and then the guy talks and says fans not running or running too much keep an eye on the coolant temp etc lol
Old Sep 28, 2013 | 07:47 PM
mrm143's Avatar
Yes lol
Old Sep 28, 2013 | 07:53 PM
HEAVY_RL's Avatar
Originally Posted by mrm143
Yes lol
ruling out the obvious.
Old Sep 28, 2013 | 09:22 PM
sOLLEx's Avatar
Keep an eye on the temp gauge, start the car and turn the temp all the way down to low where those fans are going to stay running...inspect both fans to make sure they are spinning. It's hard to discern by just the noise of them, you may only be hearing one fan. Visually check or place both hands on either side of the radiator cowl and confirm your getting air pushing back from both sides. The radiator fan control unit may be going out...or possibly a bad fan motor. Usually when the fan starts to fail intermittently, it will be after it's been warmed up and running for awhile.
Also: pull that code by going into diag mode...with the car on or running...let the OK screen load, hold down the MENU, MAP/GUIDE, CANCEL buttons together and scroll down to XM HIP...hit enter, scroll down to XM ECU, hit enter and then scroll down to diagnostic data and enter...should be a 4 digit code stored starting with a P.
Old Sep 28, 2013 | 09:26 PM
Carbon Legend's Avatar
could be the thermostat. let the car run for 2-3 minutes enough to warm up the coolant. feel the upper and lower radiator hoses and see if there is a temperature difference. could be a sticking thermostat. also could be a failing coolant temperature sensor
Old Sep 29, 2013 | 08:01 AM
mrm143's Avatar
I'll grab the code today iI deleted it yesterday...
Thermostat seems OK when fan is working car stays at normal temp
Old Sep 29, 2013 | 01:05 PM
rlerman's Avatar
Sounds like a flaky relay or switch.
Old Sep 30, 2013 | 11:27 AM
mrm143's Avatar
But which one LOL
I have been trying to get it to do it again, but it hasn't come on for 2 days LOL
I have noticed it does it more when im doing "spirited" driving
As soon as it comes on again, I will post code
Old Sep 30, 2013 | 12:04 PM
HEAVY_RL's Avatar
honestly, if you cannot replicate it and there is no fluid leaks, no over heating, and the water pump, thermostat, and rad cap are all good.
Drive until it fails is the best way to trouble shoot it IMO
Old Sep 30, 2013 | 06:03 PM
rlerman's Avatar
But which one LOL
Like you said, you need to wait until it happens again. If the fans are running when it happens, that suggests it is either the thermostat or the water pump itself. If the fans don't run, switch or relay is the issue.
Old Jul 20, 2014 | 06:36 PM
BuLtL00's Avatar
Sorry for bringing back to life an old topic,but i am experiencing a strange thing...with my a/c on only my passenger side fan comes on,works only for few seconds,it is very loud,then shuts down without completely to stop spinning,then comes back on again.The driver side fan is dead,never comes on under any surcumstances...yes,the radiator and container have coolant,the fuse on the battery is not blown,the car is not overheating and no malfunction message on MID.Please help,thanks.
Old Jul 21, 2014 | 11:41 AM
oo7spy's Avatar
From the service manual:
Originally Posted by Cooling System.pdf
FAN MOTOR TEST
1. Disconnect the 2P connectors from the radiator fan motor (A) and condenser fan motor (B). (Image attached)
2. Test each motor by connecting battery power to terminal No. 1 and ground to terminal No. 2.
3. If either motor fails to run or does not run smoothly, replace it (see RADIATOR AND FAN
REPLACEMENT ).
Old Jul 21, 2014 | 05:37 PM
BuLtL00's Avatar
Faulty cooling fan motor:dealer price $590 parts and labor(part $308+labor $240)..checked with honda dealer..few bucks less,not worth the hassle.If i buy it online $190+s&h,will prob come here next week.Will save me around $100,but i need the car this weekend for out of town long trip.Hot here in FL,dont want to mess up the car,so i will just bite the bullet and do it on wednesday,jezz..thanks for your input spy,appreciate it!
Old Jul 26, 2014 | 03:23 PM
pcloadletter's Avatar
This message just showed up today. I found a chipmunk in the radiator fan.
Old Jan 31, 2015 | 12:42 PM
MyRLgotMeLaid's Avatar
Acura RL 2005 check radiator message.
My car was doing the same thing, I though the fans were running but it was just the air forcing them to move as I was driving.
Thank god for this thread. I just replaced the battery fuse and it's cold air for days now. No more message, no more overheating. I got my fuse at a autozone. It wasn't the same size, so I cut into the copper to deepen the holes, then bent it a little bit.
Been six months, works like a champ!
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
01CLOwner
Oct 9, 2015 01:07 PM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
NSolace
Sep 3, 2015 08:02 PM
