Car lock question
Old 01-27-2011, 05:33 AM
'05 RL & '10 MDX
mlts0807's Avatar
Car lock question
When i lock the car with handle or the fob I can hear the doors lock but it doesn't beep and the lights don't flash. I went thru the keyless entry settings and everything is still set correctly so not sure what's happened. Could it be a fuse?
Old 01-27-2011, 02:29 PM
2012 Cadillac CTS-V Coupe
GoHawks's Avatar
That is normal behavior. Press the buttone a second time and you'll get the confirmation beep.
Old 01-27-2011, 02:41 PM
getakey's Avatar
mine beeps and blinks with one touch
Old 01-27-2011, 02:51 PM
037's Avatar
first touch locks doors, no beep here.
Old 01-27-2011, 03:02 PM
getakey's Avatar
is this a config setting or a change after a certain model year as mine (2005)definitely beeps with one touch?
Old 01-27-2011, 03:41 PM
037's Avatar
I have no idea, I had it set like 2 years ago and never went back. I think you can play with it in the mid.
Old 01-27-2011, 03:49 PM
getakey's Avatar
Yes, I remember it being set in the mid, but I can't remember the options. I think you were the one that did not want your HIDs to blink - wasn't that you? So that must be an option.
Old 01-27-2011, 04:27 PM
037's Avatar
um...I was the one who didn't want headlights to remain on after the car was off...I got around that by manually turning them off everytime I get out of the car...
Old 01-27-2011, 04:39 PM
getakey's Avatar
ok - thought you had issue with the blink as well, but i'm ok either way
Old 01-27-2011, 04:41 PM
getakey's Avatar
found the thread and your memory better than mine, but you had the first response
https://acurazine.com/forums/showthr...ighlight=blink
Old 01-27-2011, 06:03 PM
'05 RL & '10 MDX
mlts0807's Avatar
That is the way it's always been until recently. I can hit 10 times in a row and nothing. I double checked the mid and none of the settings have changed. That's why i was thinking it could be a fuse.
Old 01-29-2011, 10:24 AM
037's Avatar
I was wrong...first touch lock and then beep. I guess I got so used to touching it twice to be sure I must have been skipping the first beep.
Old 01-29-2011, 10:28 AM
vtr1000sp2's Avatar
OP, when you exit the vehicle, lock the doors via key fob, if it doesn't beep, place the key fob far away from the car so you don't activate the auto unlock when hand is placed on handle, take a walk around the car without the fob on you trying to open all the doors. If one of your doors isn't locked, it won't "beep". My rear passenger door stopped auto locking and I noticed it when the car failed to "beep" at me. Fixed the door lock problem and the "beep" is back.
tman570
06-11-2019 07:56 AM
Hau_nguyen91
09-06-2015 12:53 PM
jfman55
09-05-2015 02:55 PM
datadr
09-02-2015 06:46 PM
Quick Reply: Car lock question
