broken transmission mount
Old Nov 7, 2013 | 02:34 PM
asookazian's Avatar
2006 RL
110K miles
dealer stated car has a broken tranny mount. after tranny fluid exchange, tranny changes gears very smoothly (last fluid change was 50K miles ago).
i've had broken/worn engine mounts (2) on this car before. Is this normal? how many tranny mounts are there? how critical (how soon) must I fix this considering I am going to lease a new MDX next month?? thx.
Old Nov 7, 2013 | 02:36 PM
asookazian's Avatar
btw, I don't trust these dealers/mechanics as same dealer also stated battery failed but I took it to local mechanic (Bosch 3 year warranty, had it for 2 yrs) and he said it needed to have terminals cleaned and lubed which Sears/dealer doesn't seem to do on regular oil changes. cranks showed fine on the battery test at local mechanic.
so that's what you get for $22 oil change at sears...
Old Nov 7, 2013 | 03:43 PM
oo7spy's Avatar
Second opinion? Jack the car up and look yourself? If you aren't getting major clunking (sound or physical) then there isn't a whole lot to worry about.
Old Nov 7, 2013 | 06:20 PM
06RL/NBP's Avatar
My front and side motor mounts were worn out and my mechanic showed me the worn part after he installed the new ones. I had 90,000 miles on my 2006 RL. He said that the only time the rear trans mount is under stress is when you put the transmission in reverse. and that they last a lot longer than the front and side mounts.
Old Nov 7, 2013 | 06:45 PM
Mr.RL's Avatar
Im An Acura Tech And In The Five Years Ive Been With Acura Ive Seen 2 Trans Mounts Go Bad And That Was On Cars That Were 10+ Years Old Id Be Wary About That And Get A Second Opinion.
BTW, Was It An Acura Dealer You Brought It To?
Old Nov 7, 2013 | 06:55 PM
HEAVY_RL's Avatar
no, see above
SidhuSaaB
May 30, 2020 12:40 AM
bnaritomi
Feb 17, 2016 03:22 AM
joflewbyu2
Oct 8, 2015 11:16 AM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
