Brake job estimate feedback
Old May 7, 2015 | 10:33 AM
scrim67's Avatar
Estimate
Replace two front calipers with new dealer part
Replaced to rear calipers with rebuilt dealer parts
Rear brake job one year 10,000 mile warranty on pads and shoes
Replace front brakes with new Delco pads
Replaced two front rotors and two rear rotors
Does $2,000 seem reasonable?
My vehicle is a 2007 RL 160k miles
Thanks in advance for your feedback
Scrim67
Old May 7, 2015 | 10:36 AM
HELL NO! a
Old May 7, 2015 | 10:37 AM
why are they replacing calipers?
Old May 7, 2015 | 10:49 AM
RLifer's Avatar
I recently got my brake job done for little less than 1k total 'out the door' price; ordered new rotors and pads and SS brake lines through one of the vendors here, had the parts shipped to my house, set appt and took the parts to my trusted independent mechanic, and voila! Less than a thousand bucks.
oo7spy's Avatar
Front calipers cost $450-600 each.
Reman'd rear calipers cost $140-190 each.
Generic rotors typically cost $50 a piece, and pads shouldn't run more than $100 for all 4 corners.
Adding this up ranges $1400-$1800 in just parts. From a dealer, $2000 seems reasonable, but a better deal can be had. I have to ask the same question as justn though. Why do you need new calipers?
Old May 7, 2015 | 11:15 AM
projektvertx's Avatar
+3, why the new calipers???
Old May 7, 2015 | 11:22 AM
rlerman's Avatar
+4, calipers only need replacing or rebuilding if they stick., which is pretty rare.
Brake pads and rotors are $400 tops and I can do it all, as a diyer, in 4 hrs. $2k is out of control.
scrim67's Avatar
I'll have to ask why as I'm unsure
My car has 160k mi
Do calipers ever need replacing?
Old May 7, 2015 | 11:26 AM
Only if they're seized/broken. but even then you can reman them..
Old May 7, 2015 | 11:30 AM
scrim67's Avatar
I guess a second opinion is in order
Old May 7, 2015 | 11:31 AM
and they become seized from not changing brake fluid.
brake fluid is hygroscopic, which means it absorbs water from the atmosphere which can cause rust inside the brake lines leading to a seized caliper.
Old May 7, 2015 | 04:08 PM
titomang's Avatar
Dealer is definitely trying to gouge you for your money. I would steer clear from that dealership. I'm thinking all you need is new front & rear brakes and rotors.
I think Lexus dealers are even worse. The Lexus dealer wanted $1300 for new front brakes and rotors and change brake fluid for my wife's Lexus. I was like f that, bought all OEM parts from Ebay and did everything myself. Total cost was $270.
Old May 8, 2015 | 10:34 AM
ExcelerateRep's Avatar
Former Sponsor
I would definitely get a second opinion. As a general rule of thumb, we charge about 3.5 hours for pad and rotor replacement on all four corners. We clean out the calipers, properly grease all the shims and ensure everything is installed properly. With parts, labor, and CT sales tax, you'd be around $725.84 all in.
Obviously, getting new calipers would bump the cost up significantly. Just make sure you're not replacing things you don't need to!
Old May 12, 2015 | 04:57 PM
scrim67's Avatar
ok so I got a second opinion today...
the second opinion says I need new FRONT brakes
I'm thinking of ordering a front brake kit via AMAZON which includes "Black zinc OE replacement rotors plus ceramic pads kit.
The cost is about $150 which includes free shipping.
The mechanic said he'd charge me about 2 hours for labor.
The manufacturer is maxbrakes.com.
So instead of the $2k this all in seems about $400 or so.
He said I most likely do not need new calipers.
What do you think?
scrim
Old May 12, 2015 | 05:04 PM
Seems more reasonable. I'm assuming the rear brakes looked fine?
Old May 12, 2015 | 05:09 PM
scrim67's Avatar
yes....he looked and also test drove and said the rear brakes looked ok
Old May 12, 2015 | 05:21 PM
Oh ok, that's good. Honestly, I would go for something like Akebono pads and Centric rotors with the black e-coating on the hubs (I'm not 100% the ones offered on this car have the black e-coat).
Old May 13, 2015 | 01:45 PM
scrim67's Avatar
Just ordered the front rotors and pads from Centric and Akebono for about $150 including shipping.
Thanks for the feedback
Scrim
Old May 13, 2015 | 02:12 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Azine strikes again and saves a member a ton of $$$$
Old May 13, 2015 | 02:19 PM
awesome!!!
Old May 27, 2015 | 04:52 PM
scrim67's Avatar
Work was done today.
All-in to replace front rotors and pads was $350
Thanks to those who helped save me big bucks
Scrim
Old May 27, 2015 | 05:29 PM
NBP04TL4ME's Avatar
Old May 27, 2015 | 05:31 PM
wackjum's Avatar
Unbelievable how repair shops will try and push services people don't need.
Old May 27, 2015 | 05:45 PM
NBP04TL4ME's Avatar
It is but more often than not they get away with it so they play the odds
Old May 27, 2015 | 09:32 PM
oo7spy's Avatar
Dishonest business opportunities are often available, and temptation is a bitch.
Jul 16, 2017 07:33 AM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
rockyboy
Oct 2, 2015 10:45 PM
