Brake fluid requirements?
Old Aug 16, 2023 | 07:15 AM
Monkeybizness's Avatar
Read somewhere that if you don't use a specific brake fluid from Acura it will damage the master cylinder...I got a kit that included brake fluid for my upcoming brake job, but I'm scared to use it if it'll damage the system. Upgrading to goodridge stainless hoses at the same time so I'll definitely be needing brake fluid.
Anyone know the skinny on this? Also, do I need any special parts for this? I used raybestos drag reduction clips in my f-150. Are there drag reduction clips for this vehicle as well?
Old Aug 17, 2023 | 07:58 AM
marjenmiller's Avatar
I've heard that you need to use Honda/Acura brake fluid, but don't know if it is really true. My last brake job I used Honda fluid...price really isn't bad for piece of mind.
Old Aug 18, 2023 | 03:23 AM
DanL07RL's Avatar
Since i do most of the work on the car myself, I take it in for brake fluid just to get the tech's look at the car occasionally.
Old Aug 18, 2023 | 01:21 PM
projektvertx's Avatar
I don’t believe Acura brake fluid has anything specific about it that makes it special. The only fluids I stick to Acura are transmission, rear differential and front transfer case fluid, coolant and PS fluid. Brake fluid and engine oil I don’t mind outsourcing to other brands.
I’ve been running motul brake fluid for years and brake feel hasn’t changed. But again I’m case study 1:1.
Old Aug 18, 2023 | 01:58 PM
So plain ole dot4 it is then...
Old Aug 18, 2023 | 02:50 PM
Exactly!
Couillu98
Sep 10, 2013 12:20 PM
bim6180
May 28, 2006 02:06 PM
Got_3.2?
Jan 28, 2005 12:36 PM
2Sxy4YoMama
Mar 9, 2002 07:36 AM
