BMW M5 rims on a 05 RL
JDM FREAK
I'm sick of my stock rims and i think they look wrong with the RL.
The design and size just don't fit that car, and i thought that Acura would at least offer 18 inch standard and 19 optional, but no we get the same size that the RSX and civic get, ain't that a shame! a 50k+ flagship sedan with 17
Its too late anyway since i already own the vehicle, and i didn't really like the 18 chrome look accessory rim offered by Acura.
The other problem is Honda has changed the bolt pattern on the RL to what BMW use 501/20 which made the rims list even shorter and what even worse is the brake clearance
I'm wondering if anybody had tried to use BMW M5 rims on the RL because i'm about to try after replacing the center cap of course.
Also what do you guys think of having the side mirror turn signals on when the headlight unit is on just like the Mercedes Maybach?
Are you saying that BMW wheels fit the RL. If that's the case then the AC Schnitzer wheels should fit. That would be so cool.AC Schnitzer Wheels
or any of these 5 series wheels 5 series OEM wheels
Originally Posted by CGTSX2004
![Shake Head](https://acurazine.com/forums/images/smilies/shakehead.gif)
As for the rims, I would say that's your call. It would almost be sacrilege in my opinion though...
Or . . . how about . . . . the car is fine as it is without applying any crap like making the turn signals always-on? Just because MB does it doesn't mean it's right, you know.
Edit - for ppl reading this after the fact I'm not ranting on CGTSX2004, only on the content that (s)he was responding to; me and CGTSX2004 are on the same page.
Originally Posted by Karl_in_Chicago
Well would it be possible to modify the mirror lights to be green (or blue) neon? Couple that with swapping the wheels out - preferably 14" and extended outside the wheelwells by a good 6" and we are talking serious pimpdaddy ridin'! Of course this whole look would be ruined if somebody had installed the modest rear spoiler, you would definitely need some custom spoiler that extended above the roofline so you could catch all the bras and panties that would be thrown your way. Don't forget to either remove the Xenon's and replace with 'blue' lights or add some filter to make the light xtra blue.
![Scratch](https://acurazine.com/forums/images/smilies/scratch.gif)
Regardless, I stand by my statement. Lights that should always be on are parking lights, not turn signals. Since on the RL, those mirror lights serve as turn signals, they should not be on all the time.
Originally Posted by deandorsey
he said Maybach
thats where I got thrown off... I thought he meant Merc AND Maybach... even though Mayback is a Merc brand, its not a Merc Maybach
...just another stooge...
Judging by your age, you'd know more about dulled senses than I would...
CGT:
This site is closing for the weekend for upgrades (see announcements). You can still PW your way to your 10,000th post before shutdown so you can have the weekend to celebrate! Can you do it?
![Clap](https://acurazine.com/forums/images/smilies/clap.gif)
Originally Posted by 8-)
CGT:
![Chuckle](https://acurazine.com/forums/images/smilies/chuckle.gif)
Tecworld, you are mistaken. I can definately confirm that the bolt pattern for the new RL is 5x120. Watch out for some of the online wheels stores 'cos they also have it wrong.
For anyone interested in aftermarket wheels you should be looking for wheels with a high offset (35-45 range) and large X-factor (caliper clearance).
Pete
Pete
Originally Posted by Tecworld
The M5 wheels would not fit, BMW uses 5x120 size wheels, acura uses 4x114.3
The lug pattern isn't the same.
also, I doubt the M5 wheels would fit due to the width and offset.
Originally Posted by car_lost
wrong, its 5x120 for the RL and ONLY the RL as of now. the TL, TSX, RSX, MDX, NSX are 5x114.3.
AcuRL it's not that simple.
The stock offset is +55, which is not a very typical offset available in any aftermarket wheels. You will find typical "high" offset wheels (sometimes labeled as FWD wheels) are in the range of 35-45mm.
Does this mean they won't fit? ...again, it's just not that simple.
Increasing the offset puts the wheel closer to the inside of the wheel well, and the reason that high offset is needed is to position the wheel such that it doesn't stick out too much...i.e. it looks close to the original stock position.
Now an extra consideration that you must watch out for is that you need the spokes of the wheel to clear the large brake calipers on the front wheels. While you will not find many specifications on it, there is a parameter for each wheel known as the X-factor, which is the caliper clearance factor of the spokes. You need to get wheels with a high X-factor to stand any chance of clearing those huge calipers at the front.
Take a look at this thread from another RL forum, we had a good discussion on aftermarket wheels...
http://www.acura-legend.com/vbulleti...ad.php?t=61259
Pete
Pete
goldmemberererer
You can see the M5 rims on the RL here
https://acurazine.com/forums/showthr...11#post3846611
goldmember,
Thanks, but if I got it right you used PhotoShop to fit the wheels on the RL, right?
Do you have any information on whether these wheels will actually fit in real life? I know the bolt pattern is the same, but the offset can make a big difference. What is the offset on these wheels, and do you know the X-factor (clearance of the spokes over the brake caliper)?
Pete
Pete
goldmemberererer
Originally Posted by petemc
goldmember,
Pete
Pete
