Ballast or Bulb - Version 2005 RL
Old Jun 30, 2015 | 01:38 PM
01Bblack's Avatar
9th Gear
Hey All,
Experiencing a weird problem with my headlight(s). Upon first firing headlights will go on at full blast. Once warmed up the lights are fine - no discoloration or flickering. Randomly while driving one of the headlights will go out. If I turn the lights to off and turn them back to on they fire back up with no issue. This is something I have never seen and frankly I am a bit hesitant to drive the car at night! Any suggestions? Bulb/Ballast or other?
Thanks so much!
Old Jun 30, 2015 | 03:02 PM
oo7spy's Avatar
Most likely bulb. Could be ballast. Does it always happen to the same bulb? If so, a simple test is to swap the bulbs and see if it follows the bulb or stays with the ballast. Of course, simple is relative given the labor it takes to change bulbs. Some would surely use that time as reason enough to just put in new ones.
Old Jun 30, 2015 | 03:11 PM
Intermittent issues always lead to ballast failure in my experience. But definitely agree with Bond, easy way to test is to flip bulbs from side to side as a sanity check, if it's ballast, replace ballast. If it's bulbs, replace bulbs (in pairs is recommended for color consistency's sake.
Old Jun 30, 2015 | 04:06 PM
oo7spy's Avatar
I guess I am thinking of the flicker complaints we have seen here. A complete shut off does seem to point to ballast. The 2005 did have an HID TSB if I remember correctly.
Old Jul 2, 2015 | 01:29 AM
gbriank's Avatar
Yes, there is a TSB for this. Check with a local dealer to see if the replacement has been done. There were a few defective units sent out from Saitama, which caused a third replacement of the ballast and bulbs. (Happened to my RL...scan back on my posts for further information.)
Old Jul 2, 2015 | 11:47 AM
01Bblack's Avatar
9th Gear
Thanks for the help thus far everyone! I'm thinking ballast but I will check with the dealership first.
Where is the best place to purchase new Ballast(s)?
- Chris
Old Jul 2, 2015 | 02:26 PM
oo7spy's Avatar
I'm not sure if an aftermarket ballast will be compatible or not. If not, PM oemacurapartstim (board sponsor) and see if he can help you with an AZine member discount or free shipping.
Old Aug 9, 2015 | 09:12 AM
shahram72's Avatar
Did you resolve this? I had the same symptoms but new bulbs only and all is well now. They come on and stay on. Ballast is usually fine. Problem is, a bad ballast can damage new bulbs.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
hashbrown
Feb 18, 2022 11:20 AM
Sarlacc
Console & Computer Gaming
Sep 30, 2015 02:15 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
