Baking Fog Light
Old Mar 24, 2015 | 10:45 AM
  #41
NathanJax's Avatar
Originally Posted by ChocBoyWonder
I'm aiming for a week.
Not good enough... We will only allow 24hrs MAX
Old Mar 24, 2015 | 11:45 AM
  #42
oo7spy's Avatar
Originally Posted by NathanJax
Will be interesting to see if you can fit the drivers side back in since there's hardly no space behind the foglight
Let's see someone skip the long, curved pipe under the battery and retro a straight pipe. That would fix the issue.
Old Mar 24, 2015 | 01:07 PM
  #43
HEAVY_RL's Avatar
I'm working on a super top secret solution.
Old Mar 24, 2015 | 01:19 PM
  #44
oo7spy's Avatar
Might as well add a Turbo 3000 blower while you're at it.
Attwood Turbo 3000 Series In-Line Blower - 12V - White (1731-4) 22697173140
Old Mar 24, 2015 | 02:10 PM
  #45
HEAVY_RL's Avatar
I feel like I am giving to much of my design away, but that's amateur league.
Old Mar 24, 2015 | 02:20 PM
  #46
What projector is that?
Old Mar 24, 2015 | 09:30 PM
  #47
BDoggPrelude's Avatar
Seems legit to me.
Old Apr 6, 2015 | 11:55 AM
  #48
ChocBoyWonder's Avatar
Update:
I'm still at work with these. Im just waiting for my shrouds to get painted with a couple other things at the shop. I decided to leave the fog housing the reflective colour and colour match the shrouds LSM. I hope that works.
As for the lens. Heat will loosen the silicon hold, however, the problem is getting a good even grip on the lens to pull it away from the housing. Working on my second light, I heated the second lens with a heat gun moving it around the lens every 3 or 4 mins. I did this for a bout 15 mins. I then trying to use a fine chisel to see if there was any movement and there was, just ever so slightly. So I moved it around the lens to see if I could get movement all around and BAM! It chipped and cracked across haha. With this done, I put a glove on pulled the pieces out fairly easy.
I've wondering if I can use some type of suction deice to hold and pry. Do I really want to do this?!? Lexan is a lot stronger than glass and just as clear. I'll wrap them up hopefully this week and try to get pics of the steps. So far they look clean.
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
