ATF leak on transfer case
While working on the car 3 weeks ago I noticed ATF flid underneath the rear transfer case. I wiped it and sprayed it clean and fry. Today I see ATF again in the bottom of the case. I can't see where it is leaking from. I checked the drain/ glfill plug and it's very tight. Any thoughts gentlemen?
Is it red? Are you talking about the rear diff or the actual transfer case? I am actually experiencing the same thing on my rear diff. I changed the fluid a month ago, and have 10 or so drips on my garage floor directly underneath. I need to get under there and inspect it. Keep us posted if you figure it out.
Yes it's red in color and yes it's the diff not the TFT case. Will advise if I hear anything. I may take it to dealer as I think it's under the powertrain warranty?
