To anti seize or not to seize on spark plug?
Old 02-09-2016, 10:26 PM
tla11384's Avatar
Ok guys, I'm getting mixed reviews on if I should apply anti seize to the laser iridium spark plug? NGK said you don't need it but other people said it's a good idea along with some dielectric. What are your thoughts?
Old 02-09-2016, 10:46 PM
wackjum's Avatar
I've been using anti-seize on every car I've worked on. At least 20 spark plug changes. No issues.
Old 02-10-2016, 09:01 AM
08KBP_VA's Avatar
I do the antiseize just remember as the saying goes "a little dab will do ya" no reason to douse it in antiseize and while I dont have as many as wackjum under my belt I have found NO detriment to doing so.
After dealing with 1 frozen plug in a lifetime anything to prevent from happening again is worth it.
I have only done dielectric on 2 cars and both are older, 90's era. Again it wont hurt.
Old 02-10-2016, 09:10 AM
jblood37's Avatar
Maybe you don't need it, but I'm not willing to risk a seized plug by not using it. I've always used it.
Old 02-10-2016, 09:15 AM
thisaznboi88's Avatar
NGK are zinc coated (PDF from NGK provided below). not sure about other brands. I used di-electric once and it caused a misfire since some of it got on the coilpack internals.
http://www.jagrepair.com/images/Auto...1antisieze.pdf
Old 02-10-2016, 10:59 AM
oo7spy's Avatar
Received 7,247 Likes on 4,858 Posts
While a sieze or cross thread is important, it is also very important to torque them correctly on a J-series. The engine can eject the front center plug if not, and even if done correctly, Honda acknowledges 1/600 will anyway.
justnspace (02-10-2016)
Old 02-10-2016, 06:12 PM
tla11384's Avatar
So 13lb right?
Old 02-10-2016, 08:50 PM
oo7spy's Avatar
Asking the wrong guy. Check the service manual.
Old 05-08-2016, 11:38 AM
Michael Hinchey's Avatar
Originally Posted by tla11384
So 13lb right?
That is the specs from the manual. I called Ngk and they told me 18-23ftlbs. Let's just say I probably should have followed the manual. I just "ass-umed " they knew what torque spec there spark plug should be set for in my vehicle since I gave them all this info before picking the right plug.. I'm hoping I didn't cause any damage.
Old 05-08-2016, 05:56 PM
oo7spy's Avatar
Its my understanding that the threads are aluminum which is a soft metal. Going past design specs introduces the risk of stripping the threads out. That said, if your plug didn't start spinning, I think you will be okay.
Old 05-08-2016, 06:47 PM
rockstar143's Avatar
Received 19,994 Likes on 14,502 Posts
I've always done it by feel...
Old 05-10-2016, 12:50 PM
beekermartin's Avatar
I doubled it to 30 ft lbs. That is still not a lot of pressure. I checked them all after 1000 miles and they were all still at 30 ft lbs.
I very much doubt 30 ft lbs could damage the threads but YMMV. I am not saying to do this I am just saying what I did. I don't feel 13 ft lbs is enough with the risk of a plug ejecting in these motors. Also, if you talk to any technician they will tell you they do it by feel.
The following 2 users liked this post by beekermartin:
oo7spy (05-10-2016), rockstar143 (05-10-2016)
Old 05-10-2016, 12:52 PM
I feel so smart now!
Old 05-10-2016, 01:10 PM
When you do it by feel you can "feel" when a new spark plug metal gasket crushes. You then tighten it slightly past that point. I prefer to use a torque wrench because I want to know they are all equally tight.
Now it when it comes to race engines techs will spend a lot of time indexing each spark plug to line up with the intake valve. They use spacers to line each plug up. Now that takes some time!
Old 05-10-2016, 02:08 PM
If the threads are of the soft metal kind someone should mention it to Ngk. They said 2002 is prior to them changing to the softer metal.. Yikes
Old 05-10-2016, 02:10 PM
Feel to one may be different for someone else. Esp the first time doing it. Thx for the reply.
Old 05-10-2016, 02:14 PM
Originally Posted by beekermartin
When you do it by feel you can "feel" when a new spark plug metal gasket crushes. You then tighten it slightly past that point. I prefer to use a torque wrench because I want to know they are all equally tight!
. I was more worried about doing it correct so that I could know how tight it is spec'd out at so I could do it eventually without a torque wrench.
Old 05-10-2016, 06:23 PM
oo7spy's Avatar
The Legend has had an aluminum block since at least the 2G (1991?). Only thing I'm not sure about is if the threads are aluminum.
Old 05-11-2016, 01:02 AM
csmeance's Avatar
Received 2,012 Likes on 1,431 Posts
Service Manual specs call for A/S and 13ft-lbs. I used A/S on my one SP change (torqued to 13) and have had no issues (63K miles so far).
If you don't use A/S, I'd torque them to 18 - 21 ft-lbs, based on the NGK charts for Al heads. IMO, 16 ft-lbs is too low of a torque value for a non A/S install of NGKs. The link to that chart has been posted before, I'll see if I can find it.
Edit: Actually, it's 18-21.6 ft-lbs (scroll down the page a bit):
http://www.ngksparkplugs.com/tech_su...nml#installing
Overall, I think the key may be to match the appropriate torque to which ever method you choose (A/S or no A/S)...
I'd be interested to hear any supporting documentation for this statement.
see above
oo7spy (05-11-2016)
Calder
11-03-2016 11:05 AM
Powashiftin
01-09-2016 04:04 PM
Quick Reply: To anti seize or not to seize on spark plug?
