Another possible solution to the "wind noise"
Old Apr 1, 2007 | 10:38 PM
kenewag's Avatar
4th Gear
I have an '06 RL no tech package and I began experiencing a hissing noise that sounded like wind noise. I have seen several threads on this Board that led me to the shipping grommets and sealing a plastic piece under the side mirrors. Neither was my problem. My noise showed up in varying degrees at about 40-60mph.
I finally took the car in and the service tech could not hear the noise...luckily the service manager looked harder. He heard the noise while driving and then put it on hte machine inside and replicated the sound.
Turns out it was a bad bearing in my drive shaft. They replaced the drive shaft and the car is once again whisper quiet!
My hats off to the Acura Service Department in Tulsa. Hope this helps someone.
Old Apr 2, 2007 | 04:26 AM
neuronbob's Avatar
Welcome to AZ!
Several members have had the drive shaft replaced. They describe a noise that appears at varying speeds as well. After how many miles did this appear on your car?
Old Apr 2, 2007 | 10:08 PM
kenewag's Avatar
4th Gear
drive shaft problem
occurred at 9k miles
le^2
Mar 17, 2026 05:06 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
LoneRonin
Sep 28, 2015 09:11 AM
Froid
Sep 27, 2015 06:16 PM
AcuraKidd
Sep 25, 2015 11:18 PM
