another door handle thread
Old Mar 22, 2009 | 12:25 AM
b0n3's Avatar
I had my door handles replaced because of the non working dimples .. I had to disconnect my battery for a minute to get rid of the ghost door locks and "sideview reverse mirror stuck" problem
... now everything works fine ...... but
When I open my drivers side door there's a sticky sound .. almost like there's tape holding it together and "snaps" when I pull the door handle open. I felt the rubber pieces inside the handle when opened and it is a bit sticky. I'm thinking about taking some fine sandpaper to the rubber to get the "adhesive type" crap out of it.
I donno, anyone ever run into this and does it go a way after a while?
Old Mar 22, 2009 | 05:48 AM
neuronbob's Avatar
I didn't notice that, and I've had door handles replaced several times.
Old Mar 22, 2009 | 07:20 AM
jfprl's Avatar
Try rubbing/spraying the gaskets with silicone spray. make sure the silicone you get is compatible with the rubber. Test it by spraying in a styrofoam cup. If it eats the cup do not use.
Old Mar 23, 2009 | 09:19 AM
b0n3's Avatar
I used a little Goo Gone on the rubber. It seems to have resolved the issue. Hopefully my door handles won't fall off now.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
tman570
Jun 11, 2019 07:56 AM
Sep 21, 2015 08:44 AM
Sep 17, 2015 09:01 PM
