Air in Coolant
Old Mar 9, 2024 | 10:02 AM
LilBigWheel's Avatar
5th Gear
Air in Coolant
I started getting a lot of air from what I assume are exhaust gases into my coolant after I replaced a head gasket. I’m really scratching my head at the source of this air because it’s a lot of air very quickly. A full radiator of coolant can be displaced and the coolant shoots out around the overflow reservoir cap within 20 minutes of driving … any ideas of where I look next that are not head gasket would be helpful
Old Mar 9, 2024 | 10:03 AM
5th Gear
It’s a 2006 RL J35
Old Mar 9, 2024 | 10:53 AM
bleed the system. If that doesn’t work , you have to diagnose where air is coming in feom
Old Mar 9, 2024 | 02:32 PM
Pair of TLs's Avatar
Ya gotta burp it---like a baby.
Old Mar 11, 2024 | 05:42 PM
Nomgle's Avatar
Assuming you have already bled the system properly, use this
amazon.com/Block-Tester-BT-500-Combustion-Leak/dp/B06VVBSFTF amazon.com/Block-Tester-BT-500-Combustion-Leak/dp/B06VVBSFTF
to test whether the air is indeed exhaust gas (it almost certainly is though, because it's the only source of gas that has enough pressure to force itself into the cooling system).
It can only really be one of the head gaskets or a cracked block/head ... although I noticed the RL incorporates the exhaust manifold into the cooling system, so I suppose a crack in that manifold (or a failed gasket there ?) could also let the two mix.
ma777
Jul 29, 2019 09:41 AM
InfamousJamous
1G RDX Problems & Fixes
Apr 20, 2012 07:24 PM
@cUr@-TL
Aug 2, 2005 03:16 PM
gogozy
Sep 28, 2004 03:42 PM
