AFS fix?
Old Aug 14, 2011 | 10:37 PM
fongz's Avatar
AFS fix?
My AFS light had been on constantly, but yesterday, I was driving in very heavy rain on the highway, after I start my car again in the coffee shop, the AFS light is gone. But this morning, the light is on again. Could it be the mount sensor being dirty or rusted, which causing the afs to malfunction? Would it help if I take it off to clean it or use some W40 on the joints?
Old Aug 15, 2011 | 01:30 AM
Megatron's Avatar
You can't just guess at what is wrong. You need to get the code read to see what is causing the AFS light to come on. The code will pretty much tell you exactly which part is malfunctioning.
Old Aug 15, 2011 | 06:20 PM
rlerman's Avatar
it is the stroke sensor and/or the AFS unit, mostly likely the latter as I had my stroke sensor replaced and still had the problem...under warranty. Search around, there is a thread on this, one of the very common problems on these cars.
Old Aug 15, 2011 | 09:22 PM
fongz's Avatar
Today, i went to a car wash, and I spray water on the sensor purposely. When I start the car, the AFS light is gone, I am hoping it will not come back on tomorrow. I really don't wanna take out another few hundred just to have the afs light off, as I am still waitting for my Stator (field coil) to arrive to fix my AC.
Old Aug 16, 2011 | 02:48 AM
Megatron's Avatar
The part costs a little less than $200 bucks online, (like $170). It's easy to replace yourself.
Old Aug 16, 2011 | 08:12 AM
oo7spy's Avatar
Has the light come on before when it is cold? It is possible you have a bad solder joint within the sensor. My guess is the water is cooling the joint down and it contracts to make enough contact. It may be worth looking into resoldering yourself.
Old Aug 16, 2011 | 09:15 AM
fongz's Avatar
it is around 73 degrees, not too hot nor cold. This morning, the afs is back on, I am considering getting the sensor replace, I am now looking for a cheap deal online.
Old Aug 16, 2011 | 09:25 AM
oo7spy's Avatar
That did not answer my question. Never mind; good luck.
Mike734
Dec 10, 2021 01:25 PM
SidhuSaaB
May 30, 2020 12:40 AM
thegipper
Sep 28, 2015 01:01 PM
h22lude
Sep 27, 2015 06:22 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
