Acura RL Problems, please help if you can
Hello. Acura RL 2009 only sh-awd no errors. After the measurements of the 48310rjca11 module, no 12V voltage after turning the ignition on pin 1 in the sh-awd module connector, whether it is a damaged module or something does not allow 12V to turn on. What to measure and check? Measurement towards the beam pin 1 to ground 15 ohm solenoid valve coil.
Well done! It's fantastic that you were able to diagnose (and replace) a bad semiconductor.
Owning a MMC KB2 myself, I'm well aware of the quirks of this vehicle and chasing those gremlins.
I hope this car brings you joy and reliability for the future.
Cheers, theShaft
Cheers, theShaft
Odpowiedź
Wow. I'm impressed.
Kudos to not just fixing it, but coming back and telling us exactly what you did to fix it. We need more threads like these to you
Anyone find time to help me?
Everyone needs information on the Internet, but if you need help, there is no one. Anyone send me used parts? I will transfer the money for the purchase and shipping. I need plastic masking the set on the battery side in the engine compartment and a brown storage compartment on the passenger side, the key.
See this site's Black Market > Marketplace forum for buying and selling of parts. Or, try eBay or Craigslist.
tłumacz google
Moduł znajduje się w bagażniku za oparciem tylnej kanapy, ciężko wykręcić bo śruby od strony wewnętrznej, po włączeniu stacyjki na II, powinno być 12V na pinie pierwszym idącym do cewki dyferencjału, jak niema uszkodzony TPD1034 ten od strony pierwszej nogi A1 czyli przy lewej krawędzi sterownika, najlepiej użyć topnika i lutownicy na gorące powietrze. Po naprawie trzeba komputerem him hds dopisać do auta jako nowwy. Powodzenia
Hi guys,
I discovered the problem. Its the super close. When I push two times the close button key, I activate the super close, and a one or two anti-theft lock drain the battery in three days.
bye.
bye.
