AC Howl?
AC Howl?
Temps reached 101 degrees today and I was out for a leisurely drive when I started hearing a faint noise from the engine compartment. The noise came and went for the next hour or so. The AC was on full blast and I am wondering if that could be a bearing issue? After letting the car sit at home for a while and then starting it up again, the noise was still present with the car sitting at idle. Not very loud, but you could still hear it.
I have 5k miles left on my warranty and would like to know what you guys think the issue may be and or if I should have it checked out at the dealer. TIA
101 here yesterday, 100 today. No abnormal noises from the A/C and I hear everything out of the ordinary. I've put off having things checked out and ended up being sorry. If the warranty is coming to an end, have it checked out.
LL
LL
That actually crossed my mind when I first started hearing the noise. I simply put my finger over the ANC microphone and could hear the low hum but the noise from the AC never changed.
Knowing if it correlates to fan speed could help you narrow things down. If it did, it could be the motor or a leaf that got past the cabin filter and is stuck. The reason I asked if the stereo is off is I have heard noises before that sounded like the A/C but were actually my AUX cable not being plugged into anything and picking up noise.
