2005 RL front brake disc and pads
#41
After 007SPY's remark, I was afraid I was going to have to go with the forward mounted rocket launchers!!
#42
Cross drilled will actually introduce the highest risk or warping. The drilling introduces micro fractures that compromise the structure. Also, warping can be introduced my hitting a hot rotor with water, so anything that would let water all the way through the rotor would only exacerbate the likelihood of warping. If you want a look on your rotors, go slotted.
#43
Make sure to keep all brake sliding surfaces (expect the actual braking surfaces) well lubricated and free of rust. There is a special lube for the caliper pins. Also be sure to flush brake lines every other year to get any dissolved water out of the brake system.
#44
Last attempt was original Acura rotors, had them cryogenicaly treated for another $130.00...... lasted two months instead of one.......
handsom-hustla
11-13-2015 05:04 PM
asahrts
09-04-2015 05:55 PM
09-04-2015 08:03 AM
