08 RL window regulator diagnostic - next?
Old Nov 7, 2022 | 12:18 PM
80stang's Avatar
Hey Folks,
Still loving the RL but came across a problem where the driver's side window does not move. Hit the button and nothing. It was acting up the last few weeks working intermittently. So I did the remote test and all windows rolled down except for the driver's side. Does that test bypass the window switch and confirm the regulator assembly should be replaced?
Any help and guidance is appreciated. Thanks!
Old Nov 7, 2022 | 03:34 PM
Blazin Si's Avatar
My driver's side window had the same symptoms. It would work intermittently for a period of a few months and then finally it stopped working all together. I was planning to remove the door panel to diagnose the problem. If I figure it out, I'll report back.
Old Nov 7, 2022 | 04:35 PM
80stang's Avatar
Thank you, really appreciate it.
Sounds like the same exact issue and time frame mine was acting up.
cbrig
1G RL (1996-2004)
Jul 18, 2018 09:09 AM
dwest1023
Sep 4, 2007 09:32 PM
ezzat132004
1G RL (1996-2004)
Nov 11, 2006 01:43 PM
iamjae
1G RL (1996-2004)
Aug 31, 2005 09:27 PM
provench
1G TSX Problems & Fixes
Mar 4, 2005 04:53 PM
