05 RL Front windshield
Old 05-15-2017, 08:17 PM
2005 Acura RL
cyberquest's Avatar
Has anyone put a windshield in their RL recently??
mine has some rock chips in it that havent bothered me but today one of them let loose and now there is a crack right in the middle of mine and i am needing to get it replaced. money is pretty tight right now and was wondering what i would be looking at cost wise to get it replaced.
Old 05-15-2017, 09:22 PM
Turbonut's Avatar
Call Marshall's in Circleville as they have a used unit $80 and either they might install or know of a shop that will.
Old 05-16-2017, 07:47 AM
BSQ
BSQ's Avatar
The same thing happened on my wife Odyssey a couple of years ago and my insurance covered the replacement. Most insurance companies cover windshield replacement. You generally on have to pay between $50 and $100.
Old 05-16-2017, 07:49 AM
Received 8,711 Likes on 6,718 Posts
+1 on insurance, that's why you paid for it right.?
Old 05-16-2017, 10:15 AM
truonghthe's Avatar
Received 1,692 Likes on 1,307 Posts
OP there are multiple prices regarding how you gonna pay.
1. Insurance ---- whatever the deductible in your comprehensive policy stated (please stay away from Safelite they are horrible)
2. Dealer ---- Most dealer will call a glass specialist which ranging anything from $700 and up (notice they will use aftermarket glass)
3. Dealer OEM glass ----- OEM glass design to keep the noise down to minimum so OEM replacement with labor is around $1800.
Old 05-16-2017, 12:10 PM
2005 Acura RL
cyberquest's Avatar
the car is not fully insured it just has liability on it. i have a friend that can install the glass if i find a used one though.
Old 05-16-2017, 01:47 PM
BSQ
BSQ's Avatar
I would take Turbonut's advice and get the used windshield for $80 from Marshall's in
Circleville. Circleville.
Old 05-16-2017, 02:20 PM
projektvertx's Avatar
Glass replacement at a local shot like Henderson's should run about 200-300$. On my 1G RL, it was 225$ before insurance chipped anything in on it. Long story short, a chunk of overpass fell on the glass, Wayne county refused to pay since I technically couldn't prove anything. It's probably a little more on the 2G since there is more labor/parts removal involved.
Old 05-16-2017, 03:38 PM
truonghthe's Avatar
The problem is if they willing to ship them, I tried buy OEM glass for my TL and they cancelled the order and their reason was they can't ship glass that large.
Old 06-08-2017, 06:04 PM
2005 Acura RL
cyberquest's Avatar
i finally had my buddy price a new windshield for me and his cost was $96
Old 06-08-2017, 09:47 PM
Nice!
Old 06-09-2017, 12:16 AM
2007 LSM KB1 Tech w/CMBS
stevieray's Avatar
Unless things have changed in the last year, there is no such thing as an aftermarket windshield for a KB1. PPG doesn't make one and neither does Pilkington so your only option is OEM and the cheapest I have seen with all of the clips, seals, dams and garnishes is about $1100. Add another $200-250 for a reputable installer and you're looking at a $1300 windshield.
Don't ask how I know.
Old 06-09-2017, 05:07 AM
As of a few years ago, I knew there was aftermarket windshields on the 2G. I was doing chip repairs ND I had that conversation with the glass guy. Unless they discontinued all options, I find that strange.... Do you mind elaborating? I'm curious as to what's developed?
Old 06-09-2017, 10:22 AM
stevieray's Avatar
Sure. About a year ago, my original windshield was toast. Pitted, scratched, swirls, you name it. I went on the hunt and checked at my local reputable glass repair shop and I was told that neither PPG or PIlkington had an aftermarket replacement for the KB1. I even went as far as to call both manufacturers and confirmed that statement was true. I did find that there was a cheap-o Chinese replacement but it didn't the green tint band nor the noise barrier layer of the OEM and also tended to be wavy so I sucked it up and bought OEM. I have noticed that Acura has dropped the retail price on the OEM from about $1100 to $893 and if you have a local dealer that will discount for you, even less. I strongly suggest buying any dams, clips, seals & rubber sets for the OEM so as to ensure the correct fit as the foam rubber set gets destroyed when the old windshield is removed and most windshield guys don't bother with it unless you hand them all of the parts and the install instructions from the FSM and tell them to install it like it says. They'll just goop that damn 3M Window Weld on there, plop the windshield in, pop the garnishes on and walk away. My guy took his time, cleaned everything out, installed all new everything and was finished in about 3.5 hours.
You can go cheap but you'll just be buying another one in due course. Like an old friend of mine once said, "Buy the best and cry once".
projektvertx (06-09-2017)
Old 06-09-2017, 11:56 AM
chickenmagnet's Avatar
I paid $200 installed last year - no insurance - its the second one I have had done. It just got another chip last month. Lots of construction in my area.
Old 06-10-2017, 11:39 AM
truonghthe's Avatar
I once had a Safelite "special" free of charge windshield replacement through my insurance and never again I will go after no name china aftermarket. The windshield curve isn't smooth you can see where it have a straight vertical line down where it should be smooth bend, like guy mention above make sure you get all the gasket and seal kit other wise you will have moisture inside your windshield when it rain or snow. I called Safelite and complaining and they said "sorry but there is nothing we could do at this point" also they left glass chip all over my dash and seat from removal of the old one.
stevieray (06-11-2017)
