05 rl compression
Old May 26, 2021 | 09:29 AM
Bongo Vybz's Avatar
7th Gear
05 rl compression
So I have bad compression. Found out it was a bent valve.. changed it and did valve adjustments. Got both heads shaved and replaced all gaskets to where they belong. Timed it to the markings put everything back and now it doesn’t want to start. It cranks but no start ? Did I do something wrong? ..
And I put In new spark plugs yesterday .
Old May 26, 2021 | 03:50 PM
joshm213's Avatar
9th Gear
I’d start by confirming that you actually have compression now that you’ve had it fixed
Old May 26, 2021 | 07:38 PM
deepa1600's Avatar
Do you have fuel pressure?
Old May 28, 2021 | 04:09 AM
KB2toKB1FRN's Avatar
Timing marks must be off recheck and try again.
mrlunecy
May 31, 2007 12:02 PM
SpeedyV6
Aug 4, 2006 07:12 PM
Dyno_CL-S
Aug 7, 2001 05:02 PM
