05 rl
Old Jan 26, 2014 | 12:09 AM
sergiu's Avatar
05 rl
Ok so a few months ago I crashed my rl I guess I over estimated my tires and they all exploded causing an accident started saving some money bought another car to bring mine back to life it's in the shop currently
Old Jan 26, 2014 | 12:49 AM
sergiu's Avatar
Pics available in the link will post more pics
http://s42.photobucket.com/user/gujumits/profile/
Old Jan 26, 2014 | 03:49 AM
BDoggPrelude's Avatar
All 4 of your tires "exploded" all at once? That's basically impossible...
Old Jan 26, 2014 | 07:24 AM
eludethis's Avatar
7th Gear
Were you doing 135mph for more than 10minutes?
Old Jan 26, 2014 | 07:50 AM
oo7spy's Avatar
Old Jan 26, 2014 | 10:00 AM
sergiu's Avatar
I have more then one car and sometimes I would leave this one untouched for months so the sun damaged my tires really bad also those are the original tires that came with the car in 2005
Old Jan 26, 2014 | 05:45 PM
sergiu's Avatar
Exactly my stupid mistake can be a good lesson for everyone else
Old Jan 30, 2014 | 08:40 PM
sergiu's Avatar
Rl repair
Finally finished the quarter panel
Old Jan 30, 2014 | 08:47 PM
Even at 10 years old, you might have one tire fail on you. All 4 tires at once, not a chance. Only times I've ever seen a car come in with 4 blown tires was due to an impact with something in the road or vandalism.
Glad you're getting it fixed up though.
Old Jan 30, 2014 | 09:16 PM
sergiu's Avatar
That's based on ur opinion I know what happened I was there I know I didn't hit anything other then that guard rail all 4 tires exploded one blew first then when I started swerving all over the place the others fallloed I'll try to post pics of tires all got cracks all over the place
Old Jan 30, 2014 | 09:25 PM
oo7spy's Avatar
How fast?
Old Jan 30, 2014 | 09:35 PM
sergiu's Avatar
110 maybe 120
Old Jan 30, 2014 | 09:54 PM
That's still a little different than all 4 tires just suddenly exploding. One tire fails. Car starts swerving all over the place at excessive speeds. Other tires fail under the stress caused by the car swerving at excessive speeds.
Here's a video of the new Jeep Grand Cherokee failing the Swedish Moose Test. Later in the video, you can see tires blowing under the extreme stress of the vehicle loading too much weight on one corner while it is skidding. 7 brand new tires were blown during these tests. Is this a tire issue? No. The tires were never even questioned.
On a side note, this is why I always preach the importance of not going under the original tire load index specifications when replacing tires. These idiots around here with there underrated stretched tires will just look up the weight capacity of a tire, multiply it by 4 and assume it is okay since it is over the vehicle's curb weight. They don't take into account loading the vehicle and/or the amount of stress put on tires when the weight starts transferring during evasive maneuvering. Not calling you an idiot btw, sergiu.
Old Jan 30, 2014 | 10:00 PM
sergiu's Avatar
Well yeah I know there's a diff I never said they exploded all at once I just said they all exploded but i apologize about the misunderstanding
Old Jan 30, 2014 | 10:14 PM
sergiu's Avatar
Rl interior
Replacing the air back much harder then I thought
Old Jan 31, 2014 | 05:47 AM
db22's Avatar
and then you thought what?
Old Jan 31, 2014 | 07:46 AM
sergiu's Avatar
Than* smart a** lol English is my secound language I'm allowed to make mistakes
Old Jan 31, 2014 | 07:58 AM
HEAVY_RL's Avatar
Than* smart a** lol English is my second language I'm allowed to make mistakes
Old Jan 31, 2014 | 01:19 PM
oo7spy's Avatar
Keep your chin up sergiu! You're doing just fine.
Old Feb 1, 2014 | 09:47 AM
sergiu's Avatar
Can someone please help
Ok so as some of u know I just repaired my car and I had to replace rear subframe and differential well today I test drive the car and it seems it's driving only on front wheels when I looked under the car there seems to be some fluid leaking does anyone know y this is
Old Feb 1, 2014 | 09:59 AM
oo7spy's Avatar
Check and tighten the differential drain bolts (there are two) with a torque wrench to specification. After that, check your differential fluid levels (2) to see that they are filled to the bottom of the fill hole.
Did you get any SH-AWD errors?
Old Feb 1, 2014 | 12:01 PM
HEAVY_RL's Avatar
a sensor broken/not push in completely?
Does the MID show the front drive only on the display?
Old Feb 1, 2014 | 02:38 PM
sergiu's Avatar
Yes it says check ur awd system and when I drive it just shows the front wheels pulling nothing going to the rear wheels
Old Feb 1, 2014 | 05:03 PM
sOLLEx's Avatar
What code are you getting on the navi screen?
Old Feb 1, 2014 | 07:13 PM
sergiu's Avatar
Old Feb 1, 2014 | 09:11 PM
sergiu's Avatar
Now I got a 42 code
Old Feb 1, 2014 | 09:44 PM
sOLLEx's Avatar
Check the wiring harness on the rear diff to make sure everything is plugged in securely. These are codes for opens in the right clutch coil and diff fluid temp sensor. Both are mounted in the diff and should be plugged up. BTW, did you figure out where the fluid is leaking from? I assume your using a used rear diff out of a junkyard?
Old Feb 1, 2014 | 10:02 PM
sergiu's Avatar
No I haven't figured it out yet I'll pick it up tomorrow and will see, and no I'm using off my other car it only has 75k miles
Old Feb 2, 2014 | 09:41 AM
HEAVY_RL's Avatar
I think you are on the right track with sOLLEx, if its not that then you may have internal failure which is costly.
Old Feb 2, 2014 | 10:04 AM
StReCh4130's Avatar
kudos to you for putting the car back together!
Old Feb 3, 2014 | 12:33 AM
sergiu's Avatar
The system was working good on the other car I'll check everything tomorrow to make sure everything is plugged up right I'll keep u posted
Old Feb 3, 2014 | 07:56 AM
HEAVY_RL's Avatar
Thats why I think its a sensor, but with an impact like that you never know.
Old Feb 7, 2014 | 02:27 AM
godfatty420's Avatar
good luck with the repairs , keep it up
