Torque steer
Old Apr 9, 2023 | 11:57 AM
Fastshivy's Avatar
Torque steer
Weird problem 17RDX only 43,000 miles. I bought the car brand new and never a problem.
I just had the Michelin primacy tires replaced.
The car is now torque steering under full acceleration. It is a left right pull in other words it pulls in both directions (all over the road) up to about 55mph. The tires are Goodyear eagle sports. Under normal acceleration no problem. Comments?
Old Apr 9, 2023 | 01:52 PM
altair47's Avatar
If the alignment and tires are OK, then you need to look at the rear bushings of the control arms. I don't think it's a critical issue and you shouldn't worry about it.
Old Apr 9, 2023 | 07:07 PM
Fastshivy's Avatar
Thanks i suspect tires as it started when I changed them. It runs straight down the road when just cruising. The old tires wore perfectly just bad traction on a wet road...will check bushings....it is almost like the caster is off.
Drumroll
2G CL Problems & Fixes
Aug 26, 2010 09:47 AM
Jonesin
1G TSX Problems & Fixes
Apr 23, 2010 02:37 PM
JNOA
Jul 13, 2006 11:08 PM
jackacc
30
Dec 23, 2005 08:17 AM
parvo99
May 26, 2005 03:02 PM
