brake fluid flush
brake fluid is hygroscopic, which means it absorbs water from the atmosphere.
generally; auto manufactures recommend to change the fluid after year 4 of ownership and then every three years after that.
if the dealership is changing front brakes ; MOST of the labor will be already done. see if you can lump the services together and just pay for fluid.
if not and they ask you for the full labor cost of a brake fluid flush, they just want money
If you flush it, you may want to consider the Motul DOT 5.1 fluid. It's overkill for daily driver use but isn't as hydroscopic and has a higher high wet boiling point so it doesn't absorb water as easily (or at all?). It's more expensive but it's not like you're bleeding brakes very often. I switched to it and it works great.
Carbon Legend
Nov 25, 2016 01:50 AM
maharajamd
Oct 20, 2016 04:10 PM
