Would you buy this car??
Old May 19, 2023 | 08:35 PM
Tola's Avatar
5th Gear
So looking to purchase a 2017 RDX w/ tech package, 72500 miles. Maintained consistently from record up til 55000 miles. Car ran great for test drive. Found some service records at 70000 miles from dealership that showed some tranny codes which has me concerned. Details below,
Car appears to be fine 2500 miles later after fix and tranny fluid was changed, not sure if flushed several times. Should I stay away?
ServiceENGINE DIAGNOSIS
DescriptionC/S: CLIENT STATES WHEN TURNING INTO A PARKING SPOT THE VEHICLE JERKS VIOLENTLY. THE SPEAKERS POP AND THE INFOTAINMENT SCREEN GOES BLACK ON AND OFF.
Job02
  • Job 3
Job03
Service
DescriptionCustomer States all warning lights came on this morning on the way here verify client concern scan vehicle for codes and had p0848 Transmission Fluid Pressure Switch B (3rd Clutch) Circuit Low and p0777 A/T Clutch Pressure Control Solenoid Valve B Stuck O
Part NamesSWITCH ASSY.,OIL PRESSURE GASKET/PACKING
Part Numbers28600-R94-004 90471-PW7-A00
Old May 19, 2023 | 09:28 PM
altair47's Avatar
It all depends on the price of the car and the condition of the body. The transmission for this car is in the $500-700 range, so I don't think it's worth worrying about.
Old May 20, 2023 | 04:57 AM
Tola's Avatar
5th Gear
$500-700?? For a whole transmission or part that would replace if further issues with solenoid
Old May 20, 2023 | 05:49 AM
kaehlin's Avatar
That would not worry me, if the maintenance has been performed consistently and you like everything else about the car. This seems like something that was broken, and was fixed, rather than a long-term issue.
Old May 20, 2023 | 06:08 AM
Tola's Avatar
5th Gear
Thanks, I agree. Battery was replaced as well. From my research, looks like a bad battery can cause some of the issues as well,picking up later today
Old May 20, 2023 | 06:27 AM
altair47's Avatar
These are the prices for the entire transmission, it is reliable, it means it doesn’t break and nobody needs it, that’s why it’s so cheap.
https://ahparts.com/buy-used/2013-ac...ty-3m/110158-1
https://ahparts.com/buy-used/2014-ac...8c000/371764-1
brianmystery
Jan 1, 2022 11:02 AM
ps4u
Sep 15, 2012 10:47 AM
rockoutwuglockout
Oct 10, 2009 11:25 AM
njtls
Jun 4, 2003 12:24 AM
fla-tls
Feb 26, 2002 10:37 AM
