Would you buy this car??
So looking to purchase a 2017 RDX w/ tech package, 72500 miles. Maintained consistently from record up til 55000 miles. Car ran great for test drive. Found some service records at 70000 miles from dealership that showed some tranny codes which has me concerned. Details below,
Car appears to be fine 2500 miles later after fix and tranny fluid was changed, not sure if flushed several times. Should I stay away?
ServiceENGINE DIAGNOSIS
DescriptionC/S: CLIENT STATES WHEN TURNING INTO A PARKING SPOT THE VEHICLE JERKS VIOLENTLY. THE SPEAKERS POP AND THE INFOTAINMENT SCREEN GOES BLACK ON AND OFF.
Job02
Job03
Service
DescriptionCustomer States all warning lights came on this morning on the way here verify client concern scan vehicle for codes and had p0848 Transmission Fluid Pressure Switch B (3rd Clutch) Circuit Low and p0777 A/T Clutch Pressure Control Solenoid Valve B Stuck O
Part NamesSWITCH ASSY.,OIL PRESSURE GASKET/PACKING
Part Numbers28600-R94-004 90471-PW7-A00
Job02
- Job 3
Job03
Service
That would not worry me, if the maintenance has been performed consistently and you like everything else about the car. This seems like something that was broken, and was fixed, rather than a long-term issue.
Thanks, I agree. Battery was replaced as well. From my research, looks like a bad battery can cause some of the issues as well,picking up later today
https://ahparts.com/buy-used/2013-ac...ty-3m/110158-1
https://ahparts.com/buy-used/2014-ac...8c000/371764-1
ps4u
Sep 15, 2012 10:47 AM
rockoutwuglockout
Oct 10, 2009 11:25 AM
