Stripped bolt hole
Old Feb 3, 2024 | 07:30 AM
Ldalke's Avatar
Stripped bolt hole
I have a 2013 RDX, I was in the process of changing our sway bar bushings and two bolts would not brea loose. The bolt heads both broke off. It’s too tight to drill them out the bolt holes and i have to remove the base the sway bar bushings bolt to. I cannot find a bit of technical info on how to properly remove that brace. Came anyone help please. Thanks
Old Feb 3, 2024 | 09:49 AM
Ron A's Avatar
Administrator
Welcome to the forums.
The following is posted at the top of the New Member Introductions Forum: Welcome! Please introduce yourselves here, BUT ASK FOR HELP IN THE TECHNICAL FORUMS
Since this is a topic/technical issue which will require replies and discussion, this thread has been moved from the New Member Introductions Forum to the model specific forum for better response.
Old Feb 3, 2024 | 10:59 AM
Grinder
Mar 4, 2021 11:49 PM
Tammyw
Sep 17, 2019 09:08 PM
Silver™
AcuraZine Articles
37
Feb 27, 2013 05:07 PM
