Removing battery - can't seem to get negative terminal off
Old Dec 30, 2016 | 03:20 PM
buckeye_man18's Avatar
3rd Gear
I'm watching this video: https://www.carcarekiosk.com/video/2...eplace_battery
The nut holding on the negative terminal is positioned differently then the one in my 2013 Acura RDX, i.e. the nut on mine is on top, rather than on the side: https://imgur.com/a/IUj0L
When I loosen the nut (almost take it off, although I don't think it needs to be removed entirely) and the clamp is therefore loosened, the terminal still does not want to slide off.
Any ideas what I'm doing wrong? Thank you.
Old Dec 30, 2016 | 05:37 PM
rosen39's Avatar
Get some pliers and gently twist the terminal off. Clean with a wire terminal cleaner. Do you also have a battery memory saver to plug into the OBD-II port? That will save all radio presents, memory seat settings, and radio code settings.
I use this one when changing batteries:
https://www.nationaltoolwarehouse.co...FQmHswodTb0B3g
Old Dec 31, 2016 | 03:51 AM
YeuEmMaiMai's Avatar
you can use a small hammer and tap it gently on the side and it will brake loose
mszczep1
Jan 18, 2014 08:26 PM
fire919
1G TL Problems & Fixes
Feb 9, 2010 08:36 AM
Doc Holliday
18
Sep 27, 2005 03:12 PM
rb4580
Aug 21, 2003 11:01 PM
