RDX 2017 Timing Belt At 16K miles?
Was just at the dealer for my yearly oil change and was told I need to have the timing belt replaced at a cost of $2350.00. The vehicle is 7 years old, but has less than 16K miles on it due to working from home. They said it's needed due to years, not mileage, but would that still be the case with such low mileage?
They also stated that I need a fuel injector cleaning service at $290.00.
Would much appreciate your input. Thanks in advance.
That is the standard recommendation. There are many opinions on the matter (because the timing belt replacement is quite expensive). We know that the recommendation is conservative; that is, the timing belt will generally last longer than 105,000 miles or 7 years, We know that the V6 engine in these vehicles is an interference engine; that is, if the timing belt breaks while in operation, there is a chance the valves could crash into the pistons, potentially causing the engine to be not worth repairing.
Most people accept the manufacturer's recommendation on miles/time. Some people don't, either from economic constraints, or simply forgetting (harder now that these vehicles have a "Maintenance Minder' function). It is somewhat of a gamble, and becomes more 'dangerous' as time and miles go by beyond the recommendation.
You must decide for yourself how much risk you can bear. I have been driving Hondas with this issue for more than 20 years, and I do change the belt at the recommended mileage; I have never driven fewer than 105,000 miles in a 7-year period, though.
RFT!!!
Dave Kelsen
When you're used to privilege, equality feels like oppression. Always applies.
RFT!!!
Dave Kelsen
seaoc (09-26-2024)
As to “They also stated that I need a fuel injector cleaning service at $290.00”, unless you are getting a check engine light of some type, just tell them no. Over the years of Honda products, and probably a million plus miles, I’ve never had to use any product to clean fuel injectors (or carbs). I do try to use Top Tier gas if I can in my area. One of my Accords went 275,000 miles.
seaoc (09-26-2024)
After 3 years(10 years old), do a visual inspection of the belt, if the belt is like new, then do not touch it, if micro cracks appeared on the belt, then only replace the belt because time affects only it. Fuel injector cleaning service is 100% a scam, it makes sense only after 200k miles.
Good luck!
RFT!!!
Dave Kelsen
Recently I was found guilty in court of being egotistical. I am appealing.
seaoc (09-26-2024)
Altair has an important point that I should have made; the passage of time does not degrade the other parts that are generally replaced when a timing belt is changed, so while it may need replacing, the water pump and other parts do not, if they haven't gotten to the mileage limit. It is important to look for the micro cracks, as even a belt about to fail may look essentially brand new.
Good luck!
RFT!!!
Dave Kelsen
Good luck!
RFT!!!
Dave Kelsen
In my case since I'd already have to pay my mechanic just to open it all up, I'd be having him replace everything. However if it's just the owner doing all the work, I guess you could open it up and re-seal it. I'd rather be safer than sorry and get the peace of mind by replacing everything...
altair47 (09-26-2024)
6 bolts of 10 mm take 5 minutes to unscrew and 7 minutes to tighten, so it will take no more than 15 minutes to inspect the belt.
Thanks. So if the timing belt delaminates with mileage, does it also delaminate over time? Similarly, the suggestion that tires be replaced after 10 years due to potential breakdown in rubber.
I wonder how the 7 year time limit came about; was there some study done that showed after seven years time there was a significant breakdown in the timing belt? I'd sure like to see that study, if it exists.
In my experience, the timing belt tensioner starts leaking before the timing belt starts deteriorating. The belts I’ve replaced have been in still decent condition even after 120K miles and 15 years (ya i know, pushing it)…
seaoc (09-27-2024)
Our 2017 RDX has 46000 miles on it. It is my wife’s commuting vehicle. Based on my experience, I won’t do the timing belt replacement before 2027. You should be fine for a few more years with such low mileage.
RFT!!!
Dave Kelsen
"I think it's safe to say Pandora didn't have too many suitors offering her oral sex." -- Brad Simanek
seaoc (09-30-2024)
altair47. Nice work! Thanks so much for keeping track of this. Looks like all snapped belts were on very high mileage vehicles, which gives me some (and I do mean some) confidence that I can go another year or two without replacing. I had planned on selling and buying new in probably two years.
altair47 (09-30-2024)
