Passenger side mirror rotated all the way
Old Jun 17, 2019 | 10:05 AM
dzgzpy's Avatar
3rd Gear
Every time the engine is started the passenger side mirror would rotate all the way out.
is there a way to adjust it so it would go back to the memorized position?
it was ok before the last visit to dealership, guess they messed it up when doing the service.
Old Jun 17, 2019 | 11:36 AM
fcostantini's Avatar
I assume you tried to adjust the mirror to the correct position and then pressed the appropriate seat position memory button to have the car re-learn where you want it?
Old Jun 17, 2019 | 09:37 PM
dzgzpy's Avatar
3rd Gear
It is not about the mirror itself.
it is the folding part that is malfunctioning
Old Jun 20, 2019 | 10:55 AM
samiam_68's Avatar
Canadian model? Looks like it's trying to unfold itself, except it's already unfolded. Try manually folding it IN after shutting the car off.
Old Jun 20, 2019 | 11:00 AM
dzgzpy's Avatar
3rd Gear
Yes, it is canadian.
already tried that.
Old Jun 20, 2019 | 11:08 AM
samiam_68's Avatar
In that case, I would bring it back to the dealer. Hopefully, still under warranty.
Old Dec 2, 2020 | 01:12 PM
Nikhiljuneja8's Avatar
I am having the same problem with 2017 Acura RDX. On starting the car, driver side mirror rotates all the way to the back
Old Oct 20, 2022 | 07:31 PM
tchul2022's Avatar
Passenger side mirror moved to max unfold position
My Acura RDX 2018 just got the same issue. Dealer suggested to replace it about $1000CAD.
I doubted this issue was caused by car wash. Therefore I didn't want to replace it. Otherwise it will be broken in winter car wash again.
I just have an idea to stop the mirror folding when car start. I want to try cut the wire off for the folding motor.
Which wire is for the motor? I have no any experience for this mirror. Do you have any circuit diagram or suggestion for me.
The cable harness has total 15 wires.
Old Aug 23, 2023 | 05:06 PM
leif20's Avatar
Bump. Having this issue on my dad's car. Anybody seen this issue or have an idea how to fix it?
Old Nov 28, 2023 | 05:56 PM
kabalchi's Avatar
Were you able to fix the problem? How did you manage?
Old Nov 29, 2023 | 01:28 PM
kabalchi's Avatar
Hi, how did you fix your problem? Replacing the side mirror completely?
Old Jan 27, 2024 | 07:31 PM
HnR's Avatar
HnR
The orange wires on the corner are the one to cut. I opened the mirror after having a similar issue on mine. The plain orange and the one with the black strip are connected to the rotor.
Old Feb 7, 2024 | 07:11 AM
alexan10's Avatar
Fix?
Did anyone find a fix to this problem? Having the same issue
Old Apr 24, 2024 | 12:19 AM
bigplittle's Avatar
I recently banged my mirror in a parking garage and now I'm experiencing the exact same issue. The mirror will power fold in and out, but when you go to fold out to normal driving position it hyper extends past normal, to the position in OP's picture. I manually move the mirror to a semi-normal spot, but every startup it automatically moves to that hyperextended position. Anyone come up with fix? I'm sure there is just a little plastic position index jobby that's out of place.
JacOOlito
May 1, 2014 11:23 AM
Escobar7
Dec 21, 2011 02:25 PM
solefly
Jun 16, 2011 03:17 PM
ReiDLos
Mar 22, 2009 08:50 PM
ScottyNorq
Nov 4, 2007 04:38 PM
