oil spray on engine cover
Old Jul 30, 2015 | 09:10 AM
GTF's Avatar
GTF
My daughter is visiting from out-of-town, and as I was looking at her RDX, I noticed a coating of oil in engine bay...like oil was sprayed on top, but no apparent leak or puddling. Oil level OK. 6K miles. Any ideas? Help!
Old Jul 30, 2015 | 10:10 AM
andysinnh's Avatar
did she have an oil change done recently? Or any other work? Did she drive in a very wet area and get lots of splashup that could have gone inside the engine bay (could have been oil in the water that splashed up). If none of that happened, then make sure it's not another type of fluid (tranny, brake)..... Hard to tell sometimes where the source was.
Old Jul 30, 2015 | 10:36 AM
GTF's Avatar
GTF
Oil service last month. All fluids OK (oil actually high), and everywhere clean except top surfaces of engine bay.
Old Jul 30, 2015 | 02:55 PM
ceb's Avatar
ceb
There is your problem. You need to go to the dealer and have them remove the excess oil.
Overfilling can cause catalytic converter failure along with the symptoms that you've described.
oyayjoe
Jan 1, 2019 10:17 PM
sockr1
Oct 1, 2015 01:31 AM
wusty23jd
Sep 24, 2015 11:41 AM
datadr
Sep 12, 2015 09:12 PM
michaellong77
1G CL Problems & Fixes
Sep 11, 2015 12:54 AM
