FOB low battery warning
Old Oct 16, 2019 | 09:50 AM
emry's Avatar
It's been more a year that I get FOB low battery warning message when I start the car. It's strange because even though I put brand new battery in both of my FOBs I still get the message. Does anyone knows what the cause might be or what should I be look into?
Old Oct 18, 2019 | 08:20 PM
mdfree's Avatar
Possibly dirty or oxidized contacts on the battery holder?
Old Oct 18, 2019 | 08:51 PM
emry's Avatar
That's what I thought too initially. Had cleaned them with rubbing alcohol and then once again with metal brush but no result. It is strange.
Old Oct 19, 2019 | 05:01 PM
fcostantini's Avatar
I assume you tried a different brand of battery?
Old Oct 20, 2019 | 08:43 AM
emry's Avatar
Yes extactly and have done this twice once with Duracell and once with Energizer batteries. And made sure that the battery is the right type.
Old Oct 20, 2019 | 10:30 AM
mdfree's Avatar
Do both FOBs exhibit the same issue? If so, it’s probably a problem on the vehicle. Are both fobs working ok other than seeming to show low battery?
Old Oct 22, 2019 | 08:58 AM
emry's Avatar
Yes both FOBs work fine. Iam also thinking there's something wrong somewhere but can't figure out. I mean not sure where to start testing it.
Old Dec 12, 2021 | 12:46 AM
DUCRDX's Avatar
Strike Hold
Did you ever figure this out?
Old Dec 12, 2021 | 03:29 PM
dtownfb's Avatar
When I had issues with my fob battery, I took it apart and made sure everything was snapped together properly. I had a misaligned piece that was easy to overlook. And that solved my issues.
Yes, I did put new batteries in it.
schen72
ILX
Nov 12, 2018 09:48 PM
FishX
Apr 12, 2017 10:46 AM
CheeseyPoofs McNut
Feb 9, 2017 10:49 PM
mixwell
Oct 23, 2014 07:38 AM
