FOB dead after battery replacement
Old Mar 21, 2017 | 08:08 PM
FishX's Avatar
The messager that battery was low on my FOB showed up on dashboar ... . Bought new 2032 CR battery, replaced it and now FOB is dead i.e. car
does not reponds . Are there an additional steps to pair with the car ? Should I give another battery a try ...?
Old Mar 21, 2017 | 08:38 PM
vbgregg's Avatar
Did you put the battery in the correct way, or might it be in backwards?
Did you remove the little protective sticker from the battery?
Old Mar 21, 2017 | 08:42 PM
RDX-Rick's Avatar
What model year is your RDX?.
  • Do the doors unlock when you reach behind the door handles (i.e. FOB still in your pocket).
  • Does the FOB unlock your doors (including the hatch) from a distance when you use the unlock-lock-hatch buttons on the FOB?.
  • Do any LED's light up on the FOB when you press a button?.
If none of these things are happening, especially the LED's not lighting, then
  • your new battery is probably dead
  • your battery is installed backwards
  • your FOB is defective
If these things do work, then perhaps it's just your ignition sensor that is defective. Does the second key work normally with the ignition?
Old Mar 22, 2017 | 11:53 AM
Comfy's Avatar
2014 RDX AWD Tech
Also try putting in your old battery. It should still work with the warning message that battery is low. Why don't you buy a new battery (from a different shop) and give it a try? It's only a few dollars. All batteries have a limited shelf life whether used or not. It's very unusual for a keyfob to simply malfunction (though not impossible). Let us know what happens.
Old Apr 9, 2017 | 01:08 PM
OriginalLucy's Avatar
I did the same thing and the new battery was dead. Tried a different one and all good. Some of those made in China batteries are pretty unreliable
Old Apr 10, 2017 | 07:56 PM
Starflyer's Avatar
I just went to my dealer and they replaced the battery for free...
Old Apr 12, 2017 | 10:46 AM
It was just pining for the fjords.
