Curb Rash '14 RDX can I use the same guide?
Old Jan 29, 2014 | 11:34 AM
hexacu's Avatar
5th Gear
Hi everyone,
So like a idiot I managed to grind my passenger front tire against the curb slightly leading to slight curb rash at the very edges of the rim. My question is am I able to use the same DIY fix as referenced at this thread(hyperlink).
I am reading a material used to "fill" the damaged area called bondo can come off if the tire is scraped again and there is yet another material which can actually permanently "fill" . There is another product which is permanent I have it saved it somewhere at the moment but dont remember the name.
Picture of tire:
http://imgur.com/qb8dPh9
Old Jan 29, 2014 | 12:57 PM
GRDX's Avatar
That doesn't look too bad at all should be able to polish it up then spray with the proper wheel paint if you are not comfortable doing it take it to a good body shop it should look like new when done. The shop should be able to give you a price before any work is done.
Old Jan 29, 2014 | 04:43 PM
hexacu's Avatar
5th Gear
Wow really? Just polish and wheel paint? Ill do some reading about proper rim paint and polishing compounds .
thanks
Old Feb 2, 2014 | 02:56 AM
rosen39's Avatar
Sand with a little fine emory cloth, and then touch up with this color paint. I have used this color on Audi, Mercedes, Lexus wheels to touch up "curb-rash". It's a Honda paint color "Heather Mist".
http://www.carid.com/universal-paint...t-4013173.html
Attached Thumbnails Curb Rash '14 RDX can I use the same guide?-61c9yamvogl.jpg
Old Feb 3, 2014 | 03:32 AM
hexacu's Avatar
5th Gear
Will look into those two products thank you very much!
Old Feb 3, 2014 | 03:35 AM
hexacu's Avatar
5th Gear
Is there any specific grit value I need to buy or to be careful to get or I use the entire bundle and work from one grit to the next?
Old Feb 3, 2014 | 05:27 AM
rosen39's Avatar
From the picture of your "rash" I'd use 200 grit and then 400 grit. Your damage does not look that deep. Don't forget, the paint will fill in some of the scrape.
Old Feb 4, 2014 | 04:10 AM
hexacu's Avatar
5th Gear
Alright, thanks a bunch
Old Feb 4, 2014 | 07:43 AM
rosen39's Avatar
Post pictures of the finished repair.
Old Feb 5, 2014 | 08:35 PM
dmaxv8's Avatar
yeah I wouldn't use 200 grit that is to corse start 400 then 600 trust me I have painted over 75 custom cars
calrow
May 3, 2017 10:21 PM
jsonkimz
Mar 28, 2016 07:49 PM
lanechanger
Oct 13, 2015 10:56 AM
San Yasin
Sep 29, 2015 10:52 AM
dirleton
Sep 29, 2015 08:26 AM
