Cold start noise
Old Oct 22, 2022 | 03:55 PM
18RDX's Avatar
7th Gear
Cold start noise
HI everyone
I have a 2018 RDX tech, it has 106,000 KM on it so this noise only comes on during cold starts once the engine is warmed up and goes away. I've checked out underneath the car and found nothing loose. I'm trying to avoid going to the shops, I am more of a DIY person. Any suggestions would help me a lot thanks in advance by the way I've attached the sound clip
File Type: mp3
Old Oct 22, 2022 | 05:05 PM
Alex Medeiros's Avatar
alexmed2002
It sounds like something that spins like a pulley or something...
Old Oct 22, 2022 | 05:18 PM
18RDX's Avatar
7th Gear
Thanks for the input, I'll check that out tomorrow and update you guys on it.
Old Apr 10, 2023 | 09:51 AM
18RDX's Avatar
7th Gear
Update on noise
Hey everyone
I​​​​ got an update on the noise, so it's coming from the manifold converter heat shield located behind the engine, put some clamps on it now the noise is gone. Heat shield bolts gets loose in time
Old Aug 20, 2024 | 06:48 PM
MrProper's Avatar
Thanks for the update.
Have totally the same sound on my RDX and dealer could not fix it because could not reproduce the sound on warm engine.
Old Nov 10, 2025 | 01:56 PM
Thermos's Avatar
Holy moly. I've been searching all over to see if anyone has the same problem (and solution) and your sound is exactly the same thing I'm hearing in my 2013 RDX. Right after a cold start, this buzzing sound kicks in and goes away after 10-20 seconds. I went as far as replacing my accessory belt and tensioner. I was going to go down the route of engine starter next. If it's just a vibrating heat shield I will be more than pleased.
T16
Apr 4, 2023 06:48 PM
gadgetfreak
3G RDX (2019+)
Mar 20, 2022 07:54 PM
Mina_Bekhit
5G TLX Problems & Fixes
Nov 18, 2019 10:07 PM
easydrive
Apr 20, 2018 11:44 AM
glassy
Jan 30, 2015 12:14 PM
