Check blind spot system
An RLX owner had the issue of corrosion of the BSI unit: https://acurazine.com/forums/3g-rlx-...roblem-999513/
Like the previous individual suggested, I would check the battery, evn if you find it to be relatively new. And especially do so if you do a lot of short trip driving. I have found the electronic on these car to be a bit flaky if the battery condition is marginal. I'd also suggest you find a shop that can do a load test on the battery, not the test with these hand held devices which don't actually load the battery. I have a Honda Accord that was giving me some strange behavior. The dealer wanted to replace the starter at $1200. I took it to an independent and when placed on a load test the battery failed miserably. It was replaced several years ago and has never acted up again.
20 MDX has been in dealer for a week for an Acuracare-covered BSM issue. Was awaiting an Acura inspector to come and authorize replacement of the sensor and a week later it didn't work. Now they are asking Acura to authorize replacement of the BSM control module which is $1100.
Was occasionally giving me an error at startup once every 3 months or so. Finally permanently died.
Am in a loaner so no concerns waiting.
Berkshire
2G RDX Problems & Fixes
Dec 30, 2024 09:44 AM
LouET
Nov 14, 2024 03:04 PM
