Battery Sensor
Old Jun 15, 2022 | 08:14 AM
bahamasbroker's Avatar
7th Gear
Battery Sensor
Hi all I have a 2014 Acura RDX with a parasitic drain(overnight). I am determined to not let this issue beat me. So with my investigations, i also see on my battery terminal cable just at the EBS sensor that there is a break in the wire(photo). My question is what is the part number for the portion that is broken or do i have to order the whole connection, I can't find the part anywhere or maybe i am missing something. Let me add my car is in the bahamas(i am currently in Jersey visiting) and we have no Acura dealers there. Any help from the forum would be appreciated. Thanks
Old Jun 15, 2022 | 10:27 AM
dtownfb's Avatar
A Honda dealership may be able to help you.
Is that connection a standard battery connection? You may be able to get this at a parts store or at the Honda dealership.
Old Aug 5, 2022 | 11:14 AM
Tech's Avatar
I take it the connector can be unplugged from the sensor. Same as on my car but I've never needed to do so. Once off, remove one of the connector pins and solder the wire back on.
Old Aug 16, 2022 | 04:21 PM
acrdx13's Avatar
8th Gear
Does the battery drain to the point of needing a jump or just has a hard time starting? (Trying to fix a mystery problem with my 2013 is why I ask)
Old Aug 16, 2022 | 04:38 PM
7th Gear
I found my drain. Turns out it was the fuse to my seat detection. My drain was to point of every morning putting cable on and taking them off at night.
davidyeh27
Oct 29, 2018 05:17 PM
xnick101
Mar 23, 2017 12:08 PM
MA17125
4G TL Problems & Fixes
Feb 16, 2015 08:36 PM
trufbtol
Sep 9, 2014 03:27 PM
huyquangt
1G TSX Problems & Fixes
May 4, 2011 09:03 PM
