BSI on 2013 Acura RDX
I wanted to share a discovery for myself, 6 years ago a $50 BSI system was installed that worked on the basis of 2 parking sensors that reacted to all objects located at a distance of 2 meters. All the time I wanted more OEM performance, and then I stumbled upon the EASYGUARD EBS001 system and ordered OEM $ 50 lights speakers from a junkyard. The range has increased to 7-8 meters, and this system reacts only to approaching objects, I made friends with the original lamps, the wire harness connectors on the doors were made as OEM., I have been using it for a month, so far everything works great.
Thanks for watching
Thanks for watching
Looks interesting; what do you mean when you say 'lights speakers'? Does this system give you audible warnings?
RFT!!!
Dave Kelsen
"I once shook hands with Pat Boone, and my entire right side sobered up." -- Dean Martin
RFT!!!
Dave Kelsen
I think I didn’t name it correctly, most likely they are called tweeters with lights.
Yes, it has a bizzer that should hide under the dashboard, but I installed it in the right rear quarter.
Kelsen (09-06-2022)
P1zzaman
11-25-2011 01:08 PM
